hey Im just wondering which wires have you hooked you gauges up to for the ignition so you gauges come on when you start the car and which wire for the gauge lighting so it comes on when you turn your lights on.. well the light.. thanks!
there is a bundle of wire under the dash on the drivers side with black loom on them , they are going to the fuse and other places pull the loom off and your pink wires are ignition should be hot in run position use a test light to be sure you can push the tip of the test light through the wire coating , and on the lighting you need to find the fuse that runs the instrument cluster lighting and trace the wire that runs from that , it should be a gray wire dont quote me on that though !
I hope that helps you
http://memimage.cardomain.net/member_images/5/web/797000-797999/797518_143_full.jpg
I just ran it into the fuse box and towards the bottom on the right of the box, there is a red wire thats connected a clip going into a fuse, I wrapped the wire around that fuse and then plug the little red clip back into the fuse and your set, It didnt cause any issues blowing the fuse or anything like that.
Hope that helps..
i have a couple wires hooked up in my fuse box, i think a guage is hooked up to the int. lights, and one is hooked up to the cig lighter, and never had any probs with it. been like that for over a year now.
2000 Camaro V6.
