ok, I bought a 96 z and the owner of the car installed a carbon fiber voltage and oil pressure guage, but did not hook up the oil pressure guage. it's an electrical one, all the wires are hooked but one(green and white if that means anything). anyway, my question is wre do I hook up the wire?
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
Mine didnt have the green wire, mine was just the black ground, and the white wire for the accesories and such.. Hmm not sure man
it's the carbon fiber auto meter one
that's my question, where is the sender located?
nobody knows?
the sender has to go in the block , in 1 of the oil galleys
anybody have a picture of were sender is? I'll check on autometer for the sender
U need to buy the sending unit from autometer for that guage!  then u put it in one of the oil passages in the block, or T it into the same spot as the factory oil psi SU.
Email me i can get the autometer sender for you.
-Aaron
www.TurboTechRacing.com
normal place to tap for the oil pressure on a 2.4 is inbetween the cam tower just under the plug for the ign module
or on the back of the block below the water pump.......if u are using the top one for something else, such as a feedline....
