monoball setup - Suspension and Brake Forum
monoball setup
Wednesday, January 05, 2011 9:44 PM
These showeed up today.
Then I used this:
And came up with this (on a spare test knuckle)
Nets me a 1.25" taller ball joint. Should definitely help the camber curve. I basicaly just need to weld the cup into a plate, and bolt it in place of the stock ball joint. Pretty straight forward.
We'll see just how it all works out when its done.
Dan
Currently on jackstands.
Project updates and stuff: www.clubhousecustoms.com
email: dan at clubhousecustoms dot com
Re: monoball setup
Thursday, January 06, 2011 11:01 AM
looks great man!
can you upgrade to the lighter n-body aluminum knuckles or is that a 3rd gen only deal?
If it takes forever.... I will die trying. Underdog Racing
Re: monoball setup
Thursday, January 06, 2011 11:15 AM
I dont think so. Im sure James would have done it already if it was possible.
Dan
Re: monoball setup
Thursday, January 06, 2011 12:12 PM
watching.
Re: monoball setup
Thursday, January 06, 2011 1:07 PM
z yaaaa wrote:looks great man!
That is only for 3rd gen
Jason
99 Z24
LG0/LD9 for Life
10 Year Bash Veteren
Re: monoball setup
Thursday, January 06, 2011 1:31 PM
Thank god someone else had this idea - Keep us posted!
Re: monoball setup
Thursday, January 06, 2011 1:44 PM
I ordered the steel to make the plates today. I might play with these some more in a week or two. Have a few other projects I need to finish up before I go any further on this one.
Dan
Re: monoball setup
Friday, January 07, 2011 2:25 PM
No, it will work on a 2nd gen. I didn't do it because I had already swapped to H body knuckles and made adapter plates to use the J bearing.
Re: monoball setup
Friday, February 04, 2011 10:20 PM
Finally cut out the plates (again, with my trusty bosch jig saw) for the monoball setup. One is basically all done. I just need to make some relief cuts between the control arm holes so it can go all the way in (its short by about 1/8"). The other still needs the cup welded and the reliefs cut.
monoball plate vs. stock balljoint.
Dan
Re: monoball setup
Saturday, February 05, 2011 3:28 AM
Awesome man, just awesome.
perhaps for the fitment issue you could reshape the new plates to look like the original balljoints.
example:
Re: monoball setup
Saturday, February 05, 2011 6:00 AM
Ya. Thats exactly what I meant by I need to cut reliefs in the plates
Dan
Re: monoball setup
Saturday, February 05, 2011 7:41 AM
complete fail on my part, lol. totally read that wrong. thought you were going to cut the control arm...
do work!
Re: monoball setup
Saturday, February 05, 2011 1:47 PM
Those are nice! How much to make another set?
edit: If you're not interested in making another set, where'd you get the parts and reaming bit?
Edited 2 time(s). Last edited Saturday, February 05, 2011 2:08 PM
Re: monoball setup
Saturday, February 05, 2011 3:10 PM
I could be tempted into making another set.
I borrowed the reamer from a friend. Its from Speedway. I think its like 75 bux.
Dan
Re: monoball setup
Sunday, February 20, 2011 6:37 PM
looks good any more pics?
Re: monoball setup
Monday, February 21, 2011 12:19 PM
Just this one.
Dan
Re: monoball setup
Monday, February 21, 2011 9:57 PM
sex.
any info on where you sourced everything?
Re: monoball setup
Saturday, March 05, 2011 6:50 PM
I'd definitely like to know the info on the parts. This has got my mind working on a few things.
Re: monoball setup
Saturday, March 12, 2016 7:31 PM
Super old post, but someone asked me about this the other day and I dug up the info. Thought Id share it for posterity,
the stuff is from UB Machine, in New Haven IN
40-4185-075 adapter for lower 1185...
47-1215 HEIM 3/4 MONOBALL
48-5143 SNAP RING
48-1211 MONOBALL HOUSING
Dan
