Billet Rear Control Arm Bushings - Suspension and Brake Forum
Wednesday, April 03, 2013 11:56 AM
Just wanted to let you guys know that we have designed and produced a Billet style rear control arm bushing. More specs are down below. if there is a Group Buy interest let us know.
Mark
The factory Bushings are far from par, most of your clunks come from LCA (Lower Control Arm) bushings going out. We have developed a bushing using a spherical ball socket to eliminate the amount of give the arm will produce increasing the handling and traction overall. These units are made of 6061-T6 aluminum and are a bolt in for a FE3-FE1 arm.
Specs-
Material Housing- 6061-T6
CNC machined
SS 1/4-28 Flat screws
2 pin holes for alignment
Bolt in design
Com 14 T PTFT lined bearing
SS- 316 spacers
http://www.overkillengineeringmotorsports.com/
Re: Billet Rear Control Arm Bushings
Wednesday, April 03, 2013 12:36 PM
Cool design, just a little concerned about using a UNF to hold together threaded aluminum?
You going to want to have a torque spec on these for the spherical shell to seat correctly, and it will not be consistent going into aluminum.
Just my thoughts, otherwise, very cool.
Wednesday, April 03, 2013 1:13 PM
Wednesday, April 03, 2013 2:45 PM
Bobby Higgins wrote:Cool design, just a little concerned about using a UNF to hold together threaded aluminum?
65 INLB. Its all in our how to.
Mark
Wednesday, April 03, 2013 4:20 PM
Have I said giggity recently
Club Jeffie, Yea we can make that. Text or Call(908)866-1882
Wednesday, April 03, 2013 5:15 PM
Interested to see how these hold up on a street car.
Wednesday, April 03, 2013 6:13 PM
So this is for a control arm, just the rear bushing?
Any picks installed in a control arm?
Wednesday, April 03, 2013 6:31 PM
Wait, REAR control arm? or TRAILING arm?
Wednesday, April 03, 2013 6:46 PM
WHITECAVY wrote:Wait, REAR control arm? or TRAILING arm?
Rear, control arm bushing looks like. In other words its the rear bushing for the front control arm. the one that sits horizontal
Wednesday, April 03, 2013 7:10 PM
very nice, im aftaid i woul dmax them out however with laying the car out and all
Thursday, April 04, 2013 5:28 AM
Ahh I see, thx
Thursday, April 04, 2013 6:14 AM
Spencer wrote:very nice, im aftaid i woul dmax them out however with laying the car out and all
It depends. They will pivot up to 20 degrees. I am not sure how far the factory units go. Basically you will be limited by the thickness of the outside lip which is 1/8" thick.
Mark
Thursday, April 04, 2013 10:14 AM
This is definitely neat!
Thursday, April 04, 2013 12:08 PM
I'm so glad 2nd gens use horizontal bushings. Why GM ever went to vertical is beyond me.
This is a nice piece. Is the bearing press fit and SS?
Thursday, April 04, 2013 12:53 PM
Mark
Minor correction: 16* of pivot, not 20*.
Just read the cut sheet.
Thursday, April 04, 2013 1:04 PM
You know I had 16 down and then changed it. must be the com9t that pivot to 26 degrees. Either way......
Mark
Friday, April 05, 2013 5:07 PM
Hmmm pricing? I just bought Prothane bushings last month to put in, but I might be interested in these.
Saturday, April 06, 2013 6:02 AM
strat81 Online
Will they work in the ga aluminum arms?
Saturday, April 06, 2013 8:41 AM
Are Ga arm considered FE5? Let me take a look, but they should.
Mark
Micah (Shadowfire) wrote:Hmmm pricing? I just bought Prothane bushings last month to put in, but I might be interested in these.
$225 for the set
Saturday, April 06, 2013 8:45 AM
strat81 wrote:Will they work in the ga aluminum arms?
Yes they look to fit. I would just need to have a few dimensions to confirm:
-Thickness of the aluminum where the bushing goes through
- Bushing OD or the thru hole in the arm
Mark
Saturday, April 06, 2013 11:48 AM
Mark, would you be able to show an install possibly for fitment?
Stronger and durable bushings are key for us air ride fellas.
Id be interested as i blew a ball joint last year, and just upgraded my control arms.
if theres an upgrade option, id jump on these so im not chancing it again this year with all the new work ive done.
Saturday, April 06, 2013 1:57 PM
I think the GA control arms are considered FE3. I know the Jbody Prothane bushings fit them just fine.
Saturday, April 06, 2013 3:41 PM
strat81 Online
I know the prothane brushing fit but Im guessing the tolerances for the press fit are a bit more forgiving on the bushings vs. A metal spherical joint
Saturday, April 06, 2013 3:53 PM
omfg thats sick
It's nice to be injected but I love being blown.
