Full Poly Suspension Kit? - Suspension and Brake Forum
Tuesday, September 28, 2010 5:45 PM
Is there anyone who sells a Poly kit for the entire suspension (CAs, Sway Bars, etc etc.) or does everything have to be bought up separately?
Re: Full Poly Suspension Kit?
Tuesday, September 28, 2010 5:54 PM
Listening.......
Tuesday, September 28, 2010 5:56 PM
I think it has to be baught seperatly, I got mine all seperate. I could be wrong though. If I remember correct they dont sell poly end links for our cars but you can make a set of your own by using some off a different application. I think the ones I used were from a honda and I just cut the metal sleeve in the middle down a bit to match my existing ones. Hope that helps, some others may have found a different way to do it.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
Tuesday, September 28, 2010 6:07 PM
Eff. Im going to have the suspension really really apart in the coming months so I was hoping to just get it all in one shot.
Tuesday, September 28, 2010 6:11 PM
onecleancavy wrote:I think it has to be baught seperatly, I got mine all seperate. I could be wrong though. If I remember correct they dont sell poly end links for our cars but you can make a set of your own by using some off a different application. I think the ones I used were from a honda and I just cut the metal sleeve in the middle down a bit to match my existing ones. Hope that helps, some others may have found a different way to do it.
I bought the ones Moog sells
Tuesday, September 28, 2010 6:16 PM
Good deal, I could not find any when I was doing mine. Good to know though
Tuesday, September 28, 2010 8:47 PM
Advance auto had them on the shelf. It might be different in your area but you can at least order online if needed. Moog also has the "d" bushings as direct replacement if you have the 24mm bar
Wednesday, September 29, 2010 9:09 AM
I still need to find a front and rear sway bar.
Wednesday, September 29, 2010 2:28 PM
just get a stock front sway bar from a newer j in the junkyard and wait to find a used one on here for the rear.
Wednesday, September 29, 2010 3:10 PM
master kits are only available for real cars.
Underdog Racing
Wednesday, September 29, 2010 3:17 PM
z yaaaa wrote:master kits are only available for real cars.
Dammit thats what I figured.
Wednesday, September 29, 2010 4:40 PM
lol, there is one available for my fiance's 04 corolla
Wednesday, September 29, 2010 7:29 PM
shudder......
Wednesday, September 29, 2010 9:22 PM
strat81 Online
the only suspension bushings to replace on a factory j are the front sway bar, the control arms, and the torsion beam bushings.
aftermarket sways already come with poly end links. wouldn't be much of a "master kit" IMO. just buy them seperately.
Thursday, September 30, 2010 10:00 AM
Sounds good. Ill have to do that. I kept thinking there were more for some reason.
Thursday, September 30, 2010 10:48 AM
strat81 wrote:the only suspension bushings to replace on a factory j are the front sway bar, the control arms, and the torsion beam bushings.
well most master kits also come with engine and trans bushings/mounts and sometimes tie rod end boots
Thursday, September 30, 2010 11:13 AM
That would be nice if we had one of those but I dont want my car to shake like a crack addict and still have no power. Hahaha.
Thursday, September 30, 2010 11:26 AM
i just got done redoing my suspension, was real fun, poly everything, just need to get drop struts for front and rear and a sway bar for the rear. i noticed the biggest difference when i did the front sway bar ends with moog poly end links and a front strut bar. TTR (turbo tech racing.com) sells a dam good kit for the front of our cars and their a good company to go through to get stuff.
2010 Lonestar Bash 2nd place J-Body Street Class
Thursday, September 30, 2010 1:39 PM
Trey Reed wrote:i just got done redoing my suspension, was real fun, poly everything, just need to get drop struts for front and rear and a sway bar for the rear. i noticed the biggest difference when i did the front sway bar ends with moog poly end links and a front strut bar. TTR (turbo tech racing.com) sells a dam good kit for the front of our cars and their a good company to go through to get stuff.
Thanks!
-Aaron
www.TurboTechRacing.com
Thursday, September 30, 2010 1:45 PM
If only TTR made some trailing arm bushings *cough cough*
Thursday, September 30, 2010 3:18 PM
strat81 Online
and most cars have engine mounts that can benefit from replacement bushings. good luck replacing the bushings on stock j motor mounts. mounts need to be completely replaced, not just one bushing pressed out and another bushing pressed in.
Thursday, September 30, 2010 4:34 PM
...isn't the top motor mount from rk sport just an insert to be used in the stock mount?
yea, the bottom one needs to be replaced, but not everyone goes with ttr...although nicer looking, the rk sport one is much cheaper for the top.
Thursday, September 30, 2010 4:37 PM
strat81 Online
if you have a 2200 or 2.4. the eco upper mount is different and does not have an insert available AND the insert is merely that, it takes up space but the stock rubber is still there. hardly a replacement.
Thursday, September 30, 2010 5:27 PM
RK Sport cheaper??? They are $130 we are only $90....
-Aaron
Thursday, September 30, 2010 5:28 PM
strat81 wrote:if you have a 2200 or 2.4. the eco upper mount is different and does not have an insert available AND the insert is merely that, it takes up space but the stock rubber is still there. hardly a replacement.
Exactly, you still have all that soft rubber there, that is why we made a full replacement, and not just a "band aid"
-Aaron
