Car is pulling in both directions. - Suspension and Brake Forum
Thursday, March 18, 2010 6:41 PM
Hi again Org need some ideas on what is causing my car to sway to the right then left?
When i hit the throttle it sways to the right pretty fast,and will stay going right till i turn the wheel to the left.
And when i let off the throttle the car sways to the left.I just had a alignment done Tuesday(had to replace CV shaft on drivers side).
Now when I'm coasting or lite throttle my car will pull to the left,and i have to keep the steering wheel to the right to keep the car straight.
It didn't do this till last week when i pulled out onto the highway,i was making a left turn under heavy throttle,that's when it started,so i don't know if i pulled something out of whack? but i had an alignment after and its still doing it.
I already rotated the tires and no change,and pretty much everything up front is new parts or a year old,so am i just looking at an alignment or something more?
Re: Car is pulling in both directions.
Thursday, March 18, 2010 8:03 PM
Sounds like Torque steer to me.
Thursday, March 18, 2010 9:06 PM
Tinkles wrote:Sounds like Torque steer to me.
+ sticking caliper/ wheel cylinder.
Friday, March 19, 2010 5:22 AM
My first thought is caliper sticking, but second would be a crap CA bushing, or lose bolt. Any knocks coming from the front end at all?
Friday, March 19, 2010 8:20 AM
No knocking in the front end,but i did just replace the ca bushings several weeks ago with poly bushings.
Would wore out tranny bushings cause the sway in the steering?cause those bushings are in need of replacement.
I haven't had any problems with the car pulling under braking,so i didn't think a caliper would cause what its doing now.
So if it is torque steer,what can i do to remedy it?i already tightened up my sway bar and greased the ball joints and outer tie rods.
I called the alignment shop and they said swap tires left to right up front and see if that helps.
I hope i can find a fix for this cause its getting annoying.
Friday, March 19, 2010 9:51 AM
If a caliper is dragging, you will only notice it when you are NOT braking. Basically, it's still holding the rotor slightly even when you are not on the pedal. The tranny bushings could possibly cause an issue, but I doubt it.
Friday, March 19, 2010 10:25 AM
OK that makes sense,now if it is pulling to the right on acceleration,does that mean my right caliper is sticking?
Friday, March 19, 2010 12:40 PM
No, that would be torque steer. If you let off the gas, whatever way it pulls would be the caliper to check.
Friday, March 19, 2010 4:05 PM
strat81 Online
i'd check the control arm bolts again to make sure they are tight. especially since you just did the bushings.
Friday, March 19, 2010 4:18 PM
strat81 wrote:i'd check the control arm bolts again to make sure they are tight. especially since you just did the bushings.
Friday, March 19, 2010 6:15 PM
Ok i will look into the bolts tomorrow and see if any are lose.
Saturday, March 20, 2010 3:07 PM
OK checked my ca bolts today,and i found the front left ca bolt was lose,i rotated the tires to just to see what happens.
I'll drive it tomorrow to see if anything changes.
Sunday, March 21, 2010 1:38 PM
OK took her driving today,no more pulling to the right,which is great,its still pulling to the left a Lil bit,so I'll look into the caliper when i get a chance.
Monday, March 22, 2010 4:03 AM
Glad to read you found a loose bolt, I had that same issue last year and turned out my control arm bolt snapped! and I eventually got it out whit some creative thinking.
Monday, March 22, 2010 10:48 AM
Ouch, how did you manage to get the bolt out?
Monday, March 22, 2010 1:45 PM
I found my old thread if you want to kill some time, it has pics as well. my fix
Monday, March 22, 2010 5:09 PM
Man that looks like fun.
