1. Josh Klein Easy Street w/ digital kit and 2 - 380c Compressors ( and 2 relays )
2. Kyle Reber Bags front Cans rear w/ digital and 450 compressor and 1 gal. accumulator for rear
3. Joe Eazy - Easystreet w/ 10 switches, adjustable fill/dump valves, 380c and 550c compressors, 1/2" lines, 1/2" vlaves, (2) dual needle gauges, 5 gal. tank
4. BaggedCav - Easystreet w/ 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, 450c viair compressor and 5 gal. tank
5. SpyderWizard - Custom Cylinder setup(Rolled front punch welds and cutom braketry, with 1/2" fill valves 3/8" Dump valves, 2 - 100CF SCUBA tanks regulated to 250PSI, All compression fittings, 2 Switchboxes(one free, one molded in) Remote Up Down, Touchscreen control, Custom 3 gallon high pressure tank
6.brad - Easystreet w/ 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, 450c viair compressor and 5 gal. tank
7.Mike- easystreets up front custom one off irs rear with slam specialties re-6 3/8" line and valves and engine driven compressor
8. redecocav - Easystreet kit, 10 switch box, (2) dual needle gauges, 3/8" valves with 1/2" lines, Viair 380 Comp, 8gal Tank
9.jason(sndsgood) Easystreet kit standard kit 1/2" lines 1 compressor
10. yellow22 - easystreet kit, 10 switch box, added tank pressure gauge all in pillar, 450 compressor, rolled pinch welds on front and wheel wells gone in back
11. PHATLIER - Easystreet Kit by 2 gen struts (180 PSI rating) street series, 10 switches box, 1/2 air line dot with 1/2 valves size, Chrome tank 5 gallon, Two dual needle gauges and one single needle gauge with 1/4 air line dot, also get MONSTER AIR COMPRESSOR OASIS XD2000 NOT GET ENGINE DRIVEN COMPRESSOR THEY SUCKA BECAUSE OASIS BEAT EVERYTHING AND GIVING YOUR CAR SIMPLE LIFE !
13. James (ROLN19S) - AIM front struts w/Firestone bags - Easystreet Rear sleeve bags - (2)3gal. Chrome tanks - (2) Viair 380's CHROME - (8) 3/8" SMC Valves - 1/2" Parker PTC Fittings - 1/2" DOT airline - (2) Viair dual needle guages (front/rear) - (2)DEI 30amp realys - Kinetik 2000amp battery - 10 switches - Parker Water trap - SMC 1/2" Check valve - 145/175psi Pressure Switch - TUKIN 19's!!
14. Jeffy (Bagdfire) - Easystreet front strut bags, firestone 2500 bags in rear, shortened rear end 3.5 inches, custom crossmember, fully tubbed tuckin 22s in the rear
15. Scott (Hor) - Easystreet front and rear bags, 10 switch box, DNA 5 gallon tank, (2) Viair 350c compressors, 1/2" fill Valves, 3/8" dump valves, 1/2" lines, Autometer C/F air pressure gauge in pillar, All Nickle plated fittings
16. SEVENONESIXCAVY-Easystreet front bags, Eai rear air cans w/ homemade upper and lower mounts, 1- 5 gal and 1- 3 gal tank,
1/2in valves 1/2in airline, 2 parker water traps, 2 Viar 450c compressors, Eai pressure switch, AVS 5 switch box
17. Justin ~ Easystreet Fronts, Cans in back, 2 Viair 450C's, 5 gallon tank, 3/8 line & Valves, 2 dual needle and 1 single needle Easystreet gauges mounted in dash above HU, 10 swithbox, will have autopilot this week (shipped from A+ Friday)
18. 1LOUDZ24- 2nd gen -DEF BOY customs full air system. Mac air cylinders in front, firestone bags in rear, all custom brackets, 3/8 SMC valves, 8 gallon tank, custom manifolds. VIAIR 550 compressor's, sitting 1/2" off the ground with 19's.
19. Justin 2ndgen, full custom air system, sleeved bags with gr2's upfront, conitech slam specialities in the rear, 8 valve 5 gal tank, 10 switch box, in trunk, dakota digital digital guage w joystick controller, full up/down/sideside wireless, 2 viaair 450c's in trunk, cut inner fender liners out in front, rolling rears, can roll 18's @ 0 PSI! no kit
20. Kyle Scott - Easystreet kit w/ wireless remote, (2) dual needle gauges, 3/8" valves with 1/2" lines, 2x 380cc viair compressors and 8.5 gal. tank
21. Jon Hart -Easystreet Kit W/10 Switch box.
22. Herman VanDenBogaert - Easy Street kit w/ (2) dual needle gauges, 10 switches
23. WAYDERS- Easy Street kit, 2 dual needle gauges, 4 switch box(SNES controller) 3/8 valves, 1/2 lines, 380C compressor
24. Laynkav - AIM bags in front, easystreet rears- smc valves, 2 3gl tanks 3/8 airline. soon to have eazystreet fronts with 1/2 line.
25. Phewes - Easystreet strut bags, 5 gal tank, 3/8" valves, 1/2" airline, 2 Viair 450C compressors, 2 dual needle and 1 single needle Easystreet gauges, 10 switch box.
26. Nick Carney - Easystreet front bags and rear cylinders, 1/2 PARKER valves, Viair 480c Chrome Comp., 5 gal Chrome Tank, 1/2 Parker airline, 10- switch box, 2 dual pci APC gauges, single psi APC gauge, watertrap, PARKER brass fittings all the way through.
27. Kris *spinnin Cavi* - Easystreet / w 2 dual needle gagues, 3/8 valves, (2)x 450cc viair compressors, chrome 5gal tank, 8 switch box
28. Alex Keeling - Easy street struts, Viair 450C, SMC Water Trap, SMC 3/8 valves F.B.S.S, stock hubbies on 205/55/15s up front, 195/65/15s out back, 10 swtich black smoke sd.com box, also digital air ride management from autopilot, 3 Easystreet dual needles, Chrome 5 gallon tank. tubbed. lays and drags.
29. Kevin Richter - EasyStreet Air Ride Suspension, 2 Front 9-way Dampening Air Struts, 2 Rear 9-way Dampening Air Struts, 1/2" Air Lines,
(8) 3/8" Electronic Chrome 300 PSI Valves, Viair Chrome 380C Compressor, 5 Gallon D.O.T. Approved Air Tank with (8) 1/2" Ports,
145-175 PSI Pressure Switch, APP Black Smoked 10 Switch Box, ProPods Full Pillar Dual Pod, EasyStreet Dual Needle Lighted Air Pressure Gauges
30: David Stenger (FullCavEffect ~~ Air Ride Mafia). Easy Street Struts, Easy Street Manifold Valves (3/8") 1/2" Air line, Easy Street Auto Pilot Digital Controller, 5gallon tank, Viair 380C Chrome Compressor, 145-175 Pressure switch, Water trap, 6"L X 1"W X 3"T Custom made drag blocks. Soon upgrading to 1/2" SMC (4) 3/8" SMC (4) Valves. Dakota Digital Gauges, 4 switches, (up down each corner), 2nd 5gallon tank, 2 Viair 450C Compressors. Optima Battery
31. irssuntsittinlow- easystreets front lift bars in rear with re-7s az and edc compressor 8 valves, tubbed at all 4 corners
32. EasyStreet Air Ride Suspension, 2 Front 9-way Dampening Air Struts, 2 Rear 9-way Dampening Air Struts, 3/8" Air Lines, wireless controller.
33. Cotton 04 Sedan : Basic easystreet kit with digital controler and 9 way dampering all the way around
34. yellow rimed one (JASON's air ride mafia): basic digital easystreet w/digital controller (no upgrades)
35.freak04 ~easystreet kit+air ride tech. ride pro kit 3-5 gal tanks 4 450 c compressors
36.travis d - easystreet kit, orange SD 10 switchbox, viair 480, tubbed rear, cut out front,
37. Joey L (sleepysunfire) Easy street front and rear, 5 gal. tank, 2 380c compressors, 5 switch box
38. Basic Easy Street kit, 1 - 380 compressor, smoked black 10 switch box - you aint pimpin if you aint hittin switches!! Plus I'm chubby, so that makes it a little lower!!
