is there any way to adjust brake bais
Displacement=                         2.2L
Valve Train=                          OHV
Bore & Stroke=                        3.50 x 3.46
Compression Ratio=                    9 to 1
Net HP @ RPM=                         125 @ 5200
Maximum Torque Ft Lbs @ RPM=          135 @ 4000
Fuel System=                          MFI
Normal Oil Pressure: psi @ 3000 RPM=  56
ok, what do you mean by
Bias? cause that can mean a lot of things.
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
you don't have an adjustable proportioning valve if thats what your asking. ma ybe time to adjust the rear drums, whats the problem?
I am also assuming your meaning proportioning valve adjustment. And not its not possible. Unless you can find some high tech, high dollar aftermarket equip. If you think you need brake proportion adjustment on a j-body, you definatly have a super high mod car. There really isnt any need for brake adjustment on these cars. Stock truly is the best for our cars.
Rollinredcavi wrote: its not possible. Unless you can find some high tech, high dollar aftermarket equip.
of swap a stock Bonneville(?) master cylinder
Rich Grayo Jr. wrote:my guess is he justs want to put all the braking power in the back so he can do a burnout.
exactly
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
so just pull the e-brake handle. how hard is that?
by the way, say goodbye to your trans. 1 or 2 good one-wheeled burnouts, and your spider gears will disintegrate.
Rich Grayo Jr. wrote:so just pull the e-brake handle. how hard is that?
i think there called planetary gear set
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
when i pull my e-brake and try to burn out  the car just pulls off screaming the tires but the back tires stay locked up
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
Jbody305 wrote:when i pull my e-brake and try to burn out  the car just pulls off screaming the tires but the back tires stay locked up
Four possible solutions come to mind:
1) Put something heavy in the trunk
2) Make your attempt on a less grippy surface
3) Hold your service brakes as you begin to apply throttle, then release them suddenly to "launch" the car more effectively
4) Just don't.  Especially if you need a car that isn't broken.
    Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
they should make common sense a factor on determining who gets a license and who doesnt
Jbody305 wrote:Rich Grayo Jr. wrote:so just pull the e-brake handle. how hard is that?
actually its not called a planetary gear set, there is no plenetary gear set in your differential. The spider gears in the diff is what hes talking about. Don't correct someone trying to sound smart unless you actually know what  your talking about.
Rollinredcavi wrote:Stock truly is the best for our cars.
I strongly disagree.
Even if you could adjust the brake bias, how would that have any effect whatsoever on your ability to do a burnout?
What you need is more power, and more traction in the rear.  You need the power to break loose the front tires and spin them enough to eliminate traction there, and you need enough traction in the back to keep your car from just dragging the ass end around.
Then you need an LSD so you don't just detonate the diff.
Then you need someone to bitchslap you silly for wanting to do this in the first place.
Darkstars wrote:Jbody305 wrote:Rich Grayo Jr. wrote:so just pull the e-brake handle. how hard is that?
i dont know what im talkin about for one the gear set in the differential is called a pinion gear and for two he didnt specify where these so called spider gears were at, there is nothing in our trans that is called spider gear and if there is which i know theres not so prove it send in a pic where gm calls it a spider gear
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
A pinion gear is a gear that meets another gear (or rack) at a right angle (or close to a right angle).  There is no such gear inside our transmissions.
As for brake bias:  Yes a proportioning valve is one way to change bias.  But anything that increases braking at one end or the other changes bias as well.  Installing pads with a higher coefficient of friction will shift bias to that end of the car.  Increaseing rotor size will shift bias towards that end as well.  Changing the effective piston area will shift bias.  Using grippier tires on one end of the car will change bias.  Changing the weight over an axle will change bias.  Changing one thing in a vehicle will always effect something else!
Go Go OG Traction!!
OG Nick wrote:A pinion gear is a gear that meets another gear (or rack) at a right angle (or close to a right angle).  There is no such gear inside our transmissions.
look at the bottom of pic see the pinion gear its in the differential
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
might wanna change your sig since its wrong.
Rich Grayo Jr. wrote:they are not pinion gears because they do not change the axis of rotation. sorry.
what are they called then
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
Machzel08 (Teh Jew) wrote:might wanna change your sig since its wrong.
whats wrong with it sorry double post
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
Rich Grayo Jr. wrote:they are called spider gears.
not to call you a liar or anything but do you have any info to support this, just curious
Displacement=                         2.2L
Valve Train=                          OHV
Fuel System=                          MFI
the 2.2 makes 115-120 hp and 130 tq stock at the crank. the numbers have been disputed at great length on this site before, but its nowhere near 140h 150t.
