another air ride question - Page 3 - Suspension and Brake Forum
Re: another air ride question
Sunday, April 30, 2006 7:34 PM
Well i fixed it, i turned the dial all the way right and counted back 3. Seems alot better.
Monday, May 01, 2006 4:04 AM
redecocav wrote:GOOD GOD!!!!!!!!!!!!!!!!!!! 80 in the rear???? That has to ride like ass!
LOL I have my numbers confused. 20 in the front 45 in the rear.
Monday, May 01, 2006 4:48 AM
phew, I was like WOW!!!! lol
-Brandon
Monday, May 01, 2006 9:35 AM
Eazy Ent. ( 716 ) wrote:duhhh.....my battery was dieing causing those symptoms.
so im good now, but unfortunately, i appear to be losing air instantly in the rears. fronts seem pretty good holding, but as soon as i fill the rears, the drop right back to )psi
dammit
i know what you mean, mine wasnt that bad but im working on getting the leaks out. sucks. evertime i think i got it seems like they just keep leaking and leaking and leaking lol.
i had the same issue as you when i first started filling the tank, u hit the switch and you' just here nothing. but mine was caused by hardly no air in the tank so it would basically just send a shot of air to the strut then nothing. im lucky enough to have an air compressor though to help out on the fill. its also making finding leaks allot easier.
Monday, May 01, 2006 10:16 AM
if everything is tight then it could be a bad valve
Monday, May 01, 2006 10:19 AM
also, how long does it take to fill on the first fill? it seems mine runs forever, and i check the psi of the tank, and it reads 150psi, but keeps going, and thats as high as i can test currently.
should it keep going over 150? i didnt let it keep running after that, cuz i didnt wanna blow something up
RIP Saint ........ JBO
Monday, May 01, 2006 10:30 AM
if u have the easystreet it doesnt shut off till 175. its a 145 turn on and 175 off.
Monday, May 01, 2006 10:33 AM
^^^gotcha, thx for that info!!
Monday, May 01, 2006 11:42 AM
Did you buy the kit new Joe???
-Brandon
Monday, May 01, 2006 3:51 PM
redecocav wrote:phew, I was like WOW!!!! lol
OMG I still had the numbers wrong LOL. That is about as low as I can drop it hhaha.
I ride at 40 in the front and 60 in the back. There, that's over with. I have corrected myself for the last time here.
Monday, May 01, 2006 5:15 PM
redecocav wrote:Did you buy the kit new Joe???
ya, i did. well, for the most part.
i had the compressor runing for what felt like at least 15 minutes, and it never shut off. i get a lil worried when it does that, so i turn it off. should i just let it go, and hope it shuts itself off before blowing something??
ps - anyone have an airline to the gauges blow off the back of the gauge?? i did, lol
Monday, May 01, 2006 5:27 PM
The first time you run fill the compressor seems to always take a long time. I have the easy street along with the autopilot. Both times I installed my stuff last year and this year (winter sucks) it seemed to take forever to fill the tank up. It always shut off after a time though. If the pressure switch was bad it probably would not work (well at least when I had a bad switch it never turned on)
JHound
I took a Grey Hound bus to the 2005 GMSC Bash
http://memimage.cardomain.com/member_images/9/web/501000-501999/501209_5.jpg
Monday, May 01, 2006 6:36 PM
Maybe you have a preety big leak thats why it keeps running.
I used a compressure to fill mine also few times while lookign for leaks, Use LOTS of teflon tape.
Monday, May 01, 2006 7:23 PM
when i fill the bags, according to the gauges, they seem to be holding air tightly, but i still think theres something a lil off
Monday, May 01, 2006 7:44 PM
fill bags to like 140 each leave on pieces of wood under the ties at night so its on the ground. Check next day see if guages have changed.
Monday, May 01, 2006 7:46 PM
Do you not a pressure gauge for the tank?'
As stated above the pressure switch is 145 on/175 off.
It shouldnt take any longer then 3mins and 54secs to fill from 145 to 175 assuming you have a Viair 380 compressor and 5 gal tank. That is about the best I can do right now. I had a site that had all the rating for a lot of compressors, but I cant find it.
-Brandon
Tuesday, May 02, 2006 4:38 AM
but how long on first fill?
Tuesday, May 02, 2006 5:06 AM
im not sure what compressor your using but i have a viair 450 and a 5 gallon tank and i can fill my tank in about 3 1/2 mins from empty
Tuesday, May 02, 2006 7:22 AM
UniversalAirSuspension.com wrote:
Viair VC380 200 PSI 100% Duty
200 PSI
100% Duty @ 100 PSI
55% Duty @ 200 PSI
Voltage: 12V
Max Amp: 16 Amps
Max Working Pressure: 200 PSI
Max Ambient Temp: 158 Degrees F
Min Ambient Temp: -40 Degrees F
Dimensions: 9"L x 4"W x 7" H
Rated output: 1.49 CFM
5 Gal Fill Time:
0-145 PSI : 8 Min 41 Sec
0-200 PSI : 14 Min 45 Sec
165-200 PSI : 3 Min 30 Sec
This was the best I could find. What I would do is, take the average which is 11 min 42 sec and go with that beings that 175 is about in the middle of 145 and 200.
-Brandon
Tuesday, May 02, 2006 7:24 AM
^^ it seriously takes 8 mins for it to fill? geez thats terrible.
Tuesday, May 02, 2006 7:36 AM
yep. imagine me with my 8 gal tank , im about to get another though and just run 2.
-Brandon
Tuesday, May 02, 2006 7:38 AM
and I dont ever really empty my tank either, and my pressure switch is only a 110/140
-Brandon
Tuesday, May 02, 2006 8:36 AM
you should drain it once a month
Tuesday, May 02, 2006 10:22 AM
its not the valve leaking, its at the connections, i'm using the ole soapy water and can see where its at. im thinking maybe i was a bit stingy on the teflon tape. i maybe wrapped the fitting with two wraps.
Tuesday, May 02, 2006 10:33 AM
Teflon tape doesn't create the seal, it helps but the threads on the fitting should seal it. You either have a bad fitting or need to tighten it.
-Brandon
