I am new to the forum, but not new to repairing cars.
I pulled the oil pan off my 90 turbo sunbird and I see a brass fitting with a silver "tip" extending from the lower block to my crankshaft counterweight! This is located directly behind my AC compressor and looks somewhat hollow with threads possibly inside it.
There is no external tube or electric connector for it as far as I can see.
 What is this? Anyone?
 Parts are a bit tricky to obtain for this car.
I am just trying to fix the head and gasket and cleaning as much of the oil/antifreeze mix from the oil pan/tube/baffle area.
Thanks to anyone who can give insight!
There is where the crank postion sensor goes if so equiped, my 92 has one....92 - 94 all have them.
Not sure on earlier 2.0 , do you have a coil on yours?, mine is fuel injection ( MPFI ) non throttle body.
Doug in P.R.
92 Pontiac Sunbird LE, 2.0, AT, Red / Black with Grey  155K miles. Hurricane Maria Survivor ! ( It takes a licking and keeps on ticking ! ).....in Salinas, Puerto Rico!
My 2.0 OHC turbo car has a distributor. NOT DIS ignition. I should have taken a photo when I had the oil pan off. Dang.
Might have it because the motor is made in Brazil and used in Europe as Opel, was part of GM's Buick division back in the day.
Motor architecture dates back in the 70's  with the 0pel Manta and Opel GT that were sold at Buick dealerships.
Doug in P.R.
