i am swaping a 3400 motorout of a 2000 impalaint my1990 z24 5 spd.
My question is how do i wire my car to use the 3rd generation EGR valve. IS it as simple as wiring the 3400 connector to my 3.1 harness? any info is appreciated
I believe TCE makes and adapter to use the stock one. You can also delete it if you getting a custom tune which is recommended as its been found out the car will run very lean.  There is a writeup on v6z24 on how to wire it.
i will post on a new thread when i finish the build, wish me luck!
You may want to read the comments before using that method. Sounds like a problem maker.
