Can it be Done?  ( 88 and up GT  to LE?)   What body/electrical  parts are required ?
 Thanks , Doug in P.R.
92 Pontiac Sunbird LE, 2.0, AT, Red / Black with Grey  155K miles. Hurricane Maria Survivor ! ( It takes a licking and keeps on ticking ! ).....in Salinas, Puerto Rico!
Need the headlight assembly, both headlights and the relay. Not sure about the fenders or hood on the 88. As long as it has the 2ndgen setup you are fine. Unless your going with a 1st gen setup.
Rob Dotterer wrote:Need the headlight assembly, both headlights and the relay. Not sure about the fenders or hood on the 88. As long as it has the 2ndgen setup you are fine. Unless your going with a 1st gen setup.
Not the relay, the controller. They're actually two different things. You'll also need the wiring harness. It plugs into the factory firewall connector but has the additional connectors for the door motors and controller. Body wise it should be a direct swap.
Thanks for the Info.......................Doug in P.R.
I would love to do this swap.
89 355 s10 blazer
94 sunbird, 2.0 turbo 5spd getrag swap
Turbonetics turbo, intercooler, E85 20psi
I'm not , someone on the Pontiac Forums allready got the set up and was asking, couldnt find anything on the net so I figured the  guys here would know.  Thanks again.
Doug in P.R.
SUPERBEE wrote:I would love to do this swap.
We still need to get together for a beer at some point.
oh @!#$ man, I forgot you were somewhat close..... come spring time hopefully the bird will be working flawless with a turbo and 5 speed and I can take her out for a little road trip. Ill hit you up then.
89 355 s10 blazer
