I have a turbo for the Sunbird 2.0 for sale that has the manifold, downpipe, oil, and coolant lines for sale on ebay right now, but if someone here would be interested let me know. It has 53,xxx miles on it, and I really want 200 out of it if I can get it, but I have the reserve price set at 150. Check it out
ebay turbo for sale
Been looking for one of these for a while.. To bad I lack any sort of cashflow...
I did not get it sold, so if anyone is interested it is up for sale.
Do you have pics of the oil/coolant lines?
and are they complete? I know the oil lines are pretty long......one of them goes all the way to the oil filter.
That's all I need, so what kinda price with shipping to 49006?
The coolant line that goes to the thermostat housing is not on there, but it is a simple pipe thread connection, and on the one I had on the car before my current one I used a fitting screwed in and then a smaller diameter coolant line which worked well. The oil lines are there, both drain and oil feed, at least to where the oil feed comes around the back end of the block. The other coolant line is there, and this one is exactly like the other one I bought at the same time, I had to use an adapter since the 90 used a smaller coolant line, but it all works great in mine. I would do it for 200, including shipping. Here are the pics:
i would just need the coolant/oil lines, not the entire thing. I already have the turbo and manifold.
Or if you don't want to separate the lines, could you size the ends for me?
the turbo is a universal fitment, but the manifold is only for the 2.0 SOHC.
you would need a different manifold with the t25 bolt pattern to fit this to your 2.2L
check ebay, they have some.
IIRC, the 2.2L is the same from 90 to 2005 or so.
I'm interested.  Where are you located?
I am located in North Vernon IN. In fact I have an engine and auto trans with 30k on them for sale all together with the turbo for 600, you pick it up.
I'll give you $10 plus shipping for the oil return line, the big ss hose on the bottom of the turbo.
Is this set up still available?
still available?? text me eight47-848-1998 if yes
