ok i have a 1989 Sunbird 2.0ohc 5-speed.  The 2 tabs for the bolts for the mount broke right off the transmission.
Well i might try to get it welded if i can not find another tranny.
My question is what years/cars will work with this with out getting new axle shafts or anything like that.  All the junkyards that are somewhat close don't have one single Sunbird and the others i called only have the auto tranny. Not sure but maybe the 5-speed from a 2.2 will work???
The only trans that will work for you is one from a 2.0OHC. the OHV bellhousing pattern is different. Your best bet is to get it welded if you cant find one at a yard.
