Master Cylinder Problem - Second Generation Forum
Friday, April 04, 2008 12:13 PM
Hey there folx...
ok on my 91 sunbird, i have a brake fluid leak...
it's where my master cylinder meats the brake booster.......
what i want to know is if there is a o-ring that is replaceable or if i need to replace the whole master cylinder or master cylinder & booster together...
not a bad leak but enough that i have to add fluid every couple of weeks it seems, just started tho....
i am thinking that replace it all & be done with it....
but am not for sure
MikeC!
91 sunbird Convertible
3.1 with an automatic
http://www.cardomain.com/ride/3038464
Re: Master Cylinder Problem
Friday, April 04, 2008 9:14 PM
Ron Love Online
You can buy either one of two items.U can buy a master cyldr kit for about 26.00 at advance or anywhere from 85-130.00 for a new or remanfactured master cyldr.It really depends on what u really want to do.Either way u have to drain the brake fluid out and replace the with the kit or do the whole part and bleed the system after u reinstall.Yes the kit has the seals u need to resolve the leak,however as long as the whole master is ok besides it leaking where it prob leaks at the booster I would do just the kit.U can go to http://www.advanceautoparts.com to see pics of the kit/part u just simpley click online shopping and enter ur cars info yr,eng etc and do a search for brake master cyldr.How easy is that.
Sunday, April 27, 2008 1:02 AM
its leaking out the rear of the cylinder
youre alot better off getting another cylinder over trying ot put a seal kit in it
unlike in the olden days when ppl did rebuild theyre own
get a good used one from a donor car,
or a reman one from the store
good luck
-96 cavalier 2.2 auto 143k miles
