Hey all, i have a '90 Cavalier Z-24 that i just swapped a 2.8 into(inplace of a "dead" 3.1) Turns out it was the fuel pump...  I am wondering if anying has the pinouts for an '87 2.8 ECU(MAF/MAP) and the '90 with the Map only system.  I would like to go to the older one and run the maf and older EGR valve.(EGR, starter, rad, and a few other misc parts were missing from the 3.1)
I should add that the 2.8 and ecu for it are from a '87 Celebrity, so whatever Cavi had the Maf system should work.  Why can't I edit my posts BTW?
You need to be premium to edit posts.
Have you posted on V6Z24.com yet? The pinouts may even be in the How To section already.
Never thought of that site actually...  But at this point, I probly won't need to.  Looks like I put this engine in just in time for the timing chain to go.
