ok my cuz  has a 91 sunbird 2.0  and it just died were thinking its timing cause everything else is ok,  if its the case is the timing belt very hard to do??      thanks
http://www.myspace.com/crazy_cavy
A timing belt on the 2.0 is one of the easiest ones to do.
ok i need help bad   im having trouble geting the timing belt cover off, the tenshion pully is in the way.  can some one give me a qwick walk throu  please last time i did a timing belt was like 9 years ago on a datona   thanks-  jason
You have to take the belt tensioner all the way off. It is held in by a bolt on the back side of it.
is there a easy way  to get the lower sprocket off  cause now i got to take the plate  off to change the water pump
