thats right i put her on the dyno!!!!!       93hp 115 torque     and pulls all the way to redline..... not bad for stock internals and header 2.25 exhaust with a warm air intake
pulls were made in 4th gear
 jenny (93cavi 2.2 5 speed isusu )
http://
and heres some picks of jenny herself and the head i have to install on her sometime soon
ohh so t his is on a 2.2? I thought maybe were talking about the v6. but not bad numbers for the 2.2
how are those ls1 springs do you know yet? any projections on HP gains on those?
**changes are here**
yea 2.2       i dont expect to gain much with the ls1s   just prolly a little more revs so maby an extra 5 10 with the head and springs maby like 20 25
oh and thanx for the coments
also the springs look like drop ins lol
pretty good #'s sk8, i wish my 2.0 would dyno those numbers, but i'd highly doubt it, especially with my cool-ass speed holes in the muffler
2003 Cavalier 2dr. 5spd
what kinda roller rockers are you using, i wanna get a set for my 2.2
Car looks nice man, i've always wanted to get that kit for my '91...
Not bad numbers for a 2.2 either, that head should help out a bit as well.
yea well sorry i havent been on here as much (internet problems)  but on a side note some little basterd kid on a bike just slamed ito the back of her !!!!! cracked the back bumper and ripped out some of the suports for the bumper
that and the ign lock and key just went out of her (178.99 bucks)   so thare went the buget for puting the head on the car...
if any one has a lock cyl and key for sale (read cheap here) i might b able to get this head on thare yet.
thanks for all the nice words and coments
seanski   - im not shure what ones im going with yet what ones you thinking of maby we can get a set togeathor and split them
Tilt or non tilt?  Manual or auto?  I might have a spare here.
Sometimes I've been able to get it to clear up by using lock cyl lube and an air gun.  Use tons of the stuff... it will get all over everything if you're not careful.  And it sometimes takes getting a new key "cut" by the dealer (don't let them copy your old worn key, that just results in a brand new worn key).  If the local dealer doesn't charge too much you might want to try that.  Bring license, reg, and key with ya.  They usually want to see it for their records.
-->Slow
that would b great if ya had one           manual   non tilt
im hoping to get this thing at least driveable so i can go the the bash with it ....... itl b her first year!
i dont think that a new key will help ..... it wont stay in the run position  it just starts the engine then when i let go of the key flips back to the off position ... oh and then the key is a beiotch to get out of the cyl         but any advice is apreasiated
Well, that figures. The only manual / non tilt one I've got is installed in a car and I can't strip it right now.  The extra cylinder is from an auto trans car (just looked).  No button to press when turning the key back.
Maybe it's just your switch??  The cylinder assembly usually turns completely free when the switch is removed from it.  Here's a picture of the switch removed from the cylinder.
http://www.partsamerica.com/ProductList.aspx?parttype=410&ptset=A&searchfor=Ignition+Starter+Switch
I think that's the same for both types of transmissions.
-->Slow
yea maby ........ ill disconect it and see what happends        but if it is the cyl . would the auto work (just no buttion) if so i may still b intrasted......
Auto cyl might work.  I think there's a cable which prevents the key from turning to lock unless the shifter's in park.  With the cable unhooked you might be able to lock the wheel accidentally while driving.
man, I gotta get some work done to my v-6....I have a manual 3.1 and my dyno was all of 112 whp (and 180 trq) :-(
Everything Louder than Everything else
yea better get on the ball lol...... the ln2 is catchn up ......... im shootn for 200 whp and 200 wtrq        then im thinkn of thrown a helthy shot of nos in thare    lol
on my race car. 2.2 5 spd, 12:1 compression, race gas, stock head 2.25 open pipe dumps in fornt of rr tire, homemade carburated intake manifold and custom distributor, 450 lift cam with 250 duration, weber 32/36 two barrel carb made 157 hp and 162 ft lbs at the wheels in 3rd gear, we race in third that those are the only pulls we made, it easily burns the tires shifting from 2nd to 3rd in the race
man, you guys should try a V6 swap...
241.5 WHP@ 6300
220 TQ @ 5200
So around 280 Crank HP and 250 TQ
and that's on an extremely rough tune. Should be closer to 300 WHP after it's all worked out...We'll know for sure in September.
