so i had this issue last time i had my car on the road where my headlights,interior lights, trunk popper all work and then on a random day they all stop working, anyone have any ideas? i wanna put my car on the road tommorow and clearly i cant when my lgihts dont work
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Fuses? Could the ECM be frreakin out?
trunk popper is stock?
when did they start makin those..?
ya the poppwe is stock, i think all Z24s come with them(atleast ones that i have seen) some base models have them aswell
my problem was a fusable link by the start, shes good now
Mike Hecimovic wrote:ya the poppwe is stock, i think all Z24s come with them(atleast ones that i have seen) some base models have them aswell
huh? my z doesnt have one, i dont think ive ever seen one either... heh..yeah i was just about to tell you check the fuseable link by the starter...i had the same problem last year.
Ya my second gen does that everytime i turn my rear window defroster on! It overheats a fuse under my steering wheel and once it cools off all the lights work again! I've been meaning to replace it.... Anyways if your lights aren't coming on at all then you might have to buy a fuse, worst case, you might have to buy it off a GM dealer. It's not just a normal fuse... It's a 30 amp 12 volt fuse!!
