what will these take as in boring
so no one knows cmon i wana see if this block is worth building
mine is 30 over or .75 mm
so what is your bore size      you started with the 2.0 and if i rem corectly they bored and stroked it to make the 2.2    ...... so what was your final bore
thanx for the reply
ok if nobody knows do they know ware i can get this info
Nothing was bored when GM increased displacement to 2.2L.  Only the stroke was changed.   Aftermarket cast pistons are available up to .040."
-->Slow
