im hearing squeaking noises from the front  strut area.just wanted to know could it be the strut or the strut mount.it was making the noise before the i changed the struts a year ago.thanks in advance
Go stand at that corner of the car, and push straight down on it, then let go...
Could and probably is the sway bar busings. You can get a good lube from autozone or spray some silicone lube in them. Don't use wd40.
brien
89 Z24
Brien wrote:Could and probably is the sway bar busings. You can get a good lube from autozone or spray some silicone lube in them. Don't use wd40.
thanks alot it was the sway bar bushings.
