I have a 94 bird did the z24 swap leaving the head light . Bought flashers but they only have a ground and a + . How can i use them so my dash doesn't flash?
What?
Ohh, because you took out the front turn signals? Just leave the bulbs in and tuck them somewhere where they wont be hit by water or show to easily...thats what I did...
im confused by the q too... if you wanna get rid of the original flashers that were up front just cut them out where the splice is and solder the wire together... and im assuming the dash light comes on when there is an open in the circuit...
No, no...he put on a Cav front, which doesnt have the front turn signals on it...so he has the two extra bulbs dangling. If you remove the bulbs, they flash normally, but the lights on the dash will always be lit up a little bit...same thing happened to me...
Thats it 89sunbird but my question is. How could i install an aftermarket flasher that only has a + and a -? The origenal has a black, brown and green wire.If i use them green and brown to the positive the dash flashes with the flasher.
The black is ground, brown is low beam and green is high beam. Low is on when parking lights on, high during the flashing. Like I said, just leave the bulb in and tuck it somwhere it wont be seen. I wrapped mine around the 2-wire turn signal wiring and stuck it facing up so the flash wouldnt be visible on the ground...
