I was driving down the road last night and all of a sudden my headlights cut out I cut the switch off and back on and nothing I tried to put them on bright and nothing but they work tonight .what could cause this
same thing happened to my Z24 lastyear, nad if i got lucky and hit he right bump they woulod come back lol i think i have a bad relay
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Mine shut on and off if i play to much with the dimmer. might be that whole switch thing...just my 2 cents.
Check the grounds. Check the wires. Check the bulbs.
how do you set the headlights,i had to replace the housings on mine and when i bolt them in they point at the ground,so i only have one bolt in them and they are wedged up,any info would be great thanks
There should be a screw on top with a star bolt on it...you have to tighten/loosen it to adjust the height...
but what about the bottom that bolts into the housing support,it pulls it right down have any of the guys with a 92 up cavalier did theres i just want to do it without taken it to a dealership cuz having proprly adjusted headlights is important any info would be great
