These are from a 3 BAR calibration. 2 BAR tunes will need will need to add values below 45 kPa and will need to add timing between and above the MAP values in this list.
45 60 75 90 105 120 135 150 165 180 195
600 23.9 23.9 21.8 9.8 6 6 6 6 6 6 6
800 23.9 23.9 21.8 9.8 9.8 9.8 9.8 9.8 9.8 9.8 9.8
1000 23.9 23.9 21.8 14.1 10.9 9.8 9.8 9.8 9.8 9.8 9.8
1200 23.9 29.9 28.5 22.1 16.5 9.8 9.8 9.8 9.8 9.8 9.8
1400 25.7 31.3 29.2 23.9 19.3 14.1 10.2 9.8 9.8 9.8 9.8
1600 32 33.4 29.5 25 20.4 14.1 11.3 10.2 9.8 9.8 9.8
2000 39 38 32 25 22.1 17.9 13 12 12 12 12
2400 42.5 41.8 34.5 26 22.1 20 16.2 15.1 15.1 13.4 13.4
2800 41.5 40.1 36.6 27.1 22.1 20 19 16.2 15.1 14.4 13.4
3200 41.5 40.1 37.6 28.1 23.6 20 19.3 16.2 14.1 14.1 14.1
3600 40.8 42.9 38 29.9 23.9 22.1 20.4 16.2 13.7 13 13
4000 40.8 46.1 38 29.9 24.6 22.1 19 15.1 13.7 13 13
4400 40.8 46.1 38 29.9 24.6 20 18.3 15.1 14.1 14.1 14.1
4800 40.8 46.1 38 29.9 24.6 20 18.3 16.9 16.9 16.9 16.9
There's also a table which modifies spark advance under boost based on IAT. Like above, MAP is horizontal. IAT is vertical.
0 25 50 75 100
0 0 -1.1 -2.5 -3.2 -3.9
23.5 0 -1.1 -2.5 -3.2 -3.9
49.3 0 -1.1 -2.5 -3.5 -4.2
80 0 -1.1 -2.5 -3.5 -4.2
105 0 -1.1 -2.5 -3.5 -4.2
This is for an intercooled engine, 95% stock, with 5spd manual trans.
HTH
-->Slow
thanks shannen, gives me a rough idea where to start off. was gone all weekend so didn't see this till now!
Justin
1st 1st gen on air.....
