Ok, now I get to weigh in. Let me start with the easy, unargueable stuff and then I'll stick my neck out a little.
Rod bolts - ARP # 109-6001. These are the Opel/Vauxhaul 2.0 liter 16V type. I honestly can't find my receipt right now but I know I gave the part number to Stef a while back and this number sounds familiar.
Rod bearings - this is an area where I'm a little too familiar. There are plenty of chioces available but I'll give my suggestions and you can do what you feel is right for you. Once upon a time GM used to use really stout Moraine 400 series, tri-metal bearings in their high performance engines. I can't recall what the turbo Sunbirds came with but if you have an original bearing kicking around look on the back and see what it says. If it's a Moraine 400 type you could go that route and sleep well.
Otherwise I'd only consider a quality, tri-metal bearing like a Clevite 77 for an engine like ours that sees lots of abuse from high loads. The Clevite part # for us is CBL 408P. Remember, if your crank has been machined undersize the bearings will say .025 and .050 on the back to indicate if they're .010" oversized (.025 MM) or .020" (.050 MM).
I went through two sets of Federal Mogul 1490 CPA rod bearings so I can't say I'm a big fan of theirs. I believe I was suffering from detonation problems too so I can't totally blame them but still....
Remember what Slow said about superstitions?
Vandervell makes excellent bearings but I couldn't get my hands on a set when I was re-doing mine. So I went on a journey to benefit me and all of Sunbird Turbo nation to find the ultimate rod bearing.
Remember our old pal Motorman 377? He told me there were rod bearings out there that were slightly wider than our shells but would fit right in the rods and offer better load distribution. Of course he never divulged the numbers to me.
So I did a bunch of checking and found the Isuzu 2.2 in the 1998 and up Amigo seemed to have a slightly wider bearing. The only place that had them available could only get them in the Clemex brand and the part # was CB1377P. Sure enough they are slightly wider and fill up the rod and cap nicely. The line up tang is slightly different from ours so you'd need to modify it a smidge. No big deal.
Problem is Clemex is a budget "rebuilder" type bearing and has no place in a He-man engine like ours. So I hunted anew and found a bearing made by the folks who brought us Drifting and Sushi - Toga of Japan.
Toga is the high performance line of a parent company whose name I forget but Toga's are made for nitrous, turbo and generally abused engines. They're tri-metal and have a special coating on them.
Amazingly there's a distributor for Toga in New Hampshire called Flatlander Racing and they had them in stock! The Toga part number is RBIS16-HPS and Flatlander's phone number is 603-378-0090. The guy who deals with the import stuff is a tool so keep that in mind if you call them.
On install I found they were the same width as the Sunbird bearing and the tang is just like ours. WTF?! Oh well, at some point you have to say enough is enough. Sorry Sunbird Nation.
So in retrospect if you can get a set of Clevite 77's you won't go wrong. The Togas have been working well for me if you want to go that route too.
Yes, the shells are installed dry and plasti-gauged dry as well. I use Lubriplate 105 engine assembly lube and have used it for years without any regrets. I agree checking with a bore gauge is better but 95% of my engines were assembled with plasti-gauge with no regrets. With the engine in the car and the crank still in what are you going to do anyways?
Make sure your new shells snap in to place snugly. Engines that detonate tend to egg shape the rod big ends so the bearings fit loosely. I couldn't see any obvious detonation marks on your bearings but pics are only so good.
I'm using Royal Purple Racing 51 oil now. We use some of their products at work and they came in and did their dog and pony show one day. What can I say? Their addiitive package works very well and after a couple of sets of rod bearings you'll want every ounce of protection you can get. Having fun changing your bearings? Want to do it again? No, I'm not on their payroll you haters!
By the same token my sister bought my car new and only used conventional motor oil for the 16 years she owned it. I had her in the habit of changing the oil around 2000 miles because she loved to beat on it. The only problem she ever had was a blown head gasket at 46,000 miles. I let Slow borrow the turbo off it and it worked fine for him and has never been rebuilt. So I have to wonder about ash deposits and that kinda stuff.
One other thing on rod bolts. You may not want to use the ARP's in your rods now because they have a different clamping force than stock and may cause the egg shaping effect when you torque them up. If you were re-sizing the rods they would just be torqued up and honed to size. You may want to check with your machinist or ARP to verify this. In that case just get a new set of GM's. They lasted this long right?
I had to laugh at your dealership mechanic comment since I was one years ago. I don't want to upset any dealership mechanics who may read this so I won't say any more. They probably found it funny too.
On a fresh engine fire-up I unplug the coil and crank it for short intervals until I get oil pressure. I'm 99% positive I did that when I fired this engine up for the first time. No, I'm not gonna prove it now since it's 11:45 PM and my family is asleep!
I think that'll do it. If not fire back. Oh and the first engine I ever rebuilt was an AMC 390 in my '69 AMX. The only thing it ever spun was tires.
Tony
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
