This may sound stupid but is there any way to install a turbo system on an 88 2.0 anything an old one a new one i dont really care just some one help me
Here is something i found on a site a while back when i wanted to turbo my Sunbird LE.
You will need:
T-25 turbo, turbo exhaust manifold, higher psi fuel pump, downpipe, oiling lines, boost controller, fuel pressure regulator, dual gauge pod (gaugepods.com), air fuel meter, boost gauge, exhaust manifold gasket,oil pan gasket, plenty of vaccume hose, various hose clamps, vaccume "T" fittings, a 1-way check valve, pistons from a 2.0 turbo engine (to lower compression, and they are forged), and probably a few other parts I forgot to mention.
Also get a chilton's manual, it might help you in assembling your engine with these parts. I'd actually get someone who knows what they are doing to help you set it all up. Rememer, the easiest way to turbocharge your 2.0 is just to swap it for an already turbocharged 2.0 engine!
Got it from LT3engine.tk Some good info in the Info/Specs section.
i see you have a cavalier, meaning its a 2.0 ohv. your easyest way to turbo it is get a 2.0l turbo motor from a sunbird and drop it in with the wiring harness, ecm, tranny, and all related things.
thanks every body ill se what i can do
yeah there has been a few people who boosted 2nd gens 2.0/2.2 but I can't quite figure out who it is though.
**changes are here**
i have one:p
1st 1st gen on air.....
I have an 84 Skyhawk with a 92+ 2.0 OHC that I want to turbo. I already have the exhaust manifold, turbo, and wastegate. Now all I need is to figure out where the oil and coolant lines connect and make an air box to push it thru the tbi... I think... lol. I have the Chiltons and Haynes manuals and neither of them talk about the turbo connections. Ive searched in here and havent come up with anything yet. Anyone around Houston with this setup that might be able to help me out?
I plan on living forever... so far so good
just run oil cooled and block off the coolant passages in the turbo.
the oil feed is in the back of the block theres a little threaded cap that takes a torqus bit to get out or you could just T off you oilpressure sending unit.
Ive done it on a 92 Sunbird LE on stock internals and running 8 psi with no problems.need any more help you can email me
Swap to the 2.0 turbo engine and trans. Find a donor car and swap, or better yet.. buy another car, as you'll get the GT suspension and steering too which is well worth it. Trying to run higher power thru the N/A version and trans is asking for part failure as it was never designed too handle any more power then stock. When an OEM changes parts for a higher output motor it's a clue that they NEEDED too.
I havent had any problems and I got everything from a 89Grand Am and the tanny was the same as the one in mine they are both automatics so if the grand am tranny held up to mine should and has
