Will a sport suspension (FE3) steering rack & pinion assembly bolt right on and work with a standard FE1 "soft ride" suspension?  If other mods are required to use a FE3 R&P on a FE1 car, what are they?
No mods needed its a direct swap.  The only one that is a little different is the Manual rack (No Power steering) it needs a different coupler to connect to the steering column
what cars can i find the manual rack in and is the coupler that hard to swap
