When you install a tach where would you mount it? Is it necessary to drill through the dash or something? Or is there any other way to do it? And lastly, does the automatic 2.2 cavie have the white wire near the glovebox?
You can mount it anywhere you want. Where and what you drill through is up to where you want it. Most people put it somewhere near the stock gauge cluster, or next to the A pillar. The mounting options (drill and screw, strap, etc) will depend on the tach you are using.
Judging from your username, you have a 93 Cav (please fill out your registry, that way we can all be positive when you ask questions). I'm 100% sure the 94 Cavs use the B11 wire on the center connector of the ECM (its white). I'm not 100% sure of the 93s, since they have a different ECM.
Sorry about the registry it's filled out now. I picked up a sunpro tach today, so will this have to get hooked into the engine coils or is there even  a white wire I can use?
Update: I read the application guide, it said on the 93 cavalier you had to run it to the coil packs at the rear of the engine and on the 94 you had to run it to the white wire located in the dash? Is this true before anything gets messed up?
Thanks in advance
Nevermind, it's confirmed: I checked the application guide on the Sunpro website. Below I think this chart will help everyone with their tachometer confusion...
MODEL
YEAR 	ENGINE
SIZE 	DEVICE
NAME 	DEVICE
LOCATION 	WIRE
COLOR 	PIN ID 	TACH
ADAPTER
1984-86 	1.8L ALL 	NEGATIVE SIDE OF IGNITION COIL 	TOP OF ENGINE 	WHITE 	N/A 	N/A
1984-86 	2.0L 	DISTRIBUTOR 	DISTRIBUTOR 	WHITE 	A 	N/A
1985-86 	2.8L 	DISTRIBUTOR 	DISTRIBUTOR 	WHITE 	A 	N/A
1987 	2.0L 	DIS IGNITION MODULE 	UNDER IGNITION COILS 	WHITE 	A 	N/A
1987-89 	2.8L 	DIS IGNITION MODULE 	UNDER IGNITION COILS 	WHITE 	C 	N/A
1988-89 	2.0L 	DIS IGNITION MODULE 	UNDER IGNITION COILS 	BLACK/WHITE STRIPE 	A 	N/A
1988 	2.4L 	POWERTRAIN CONTROL MODULE 	PASSENGER SIDE FRONT FENDER WELL 	WHITE IN CONNECTOR 2 	10 	N/A
1990 	2.2L 	DIS IGNITION MODULE 	REAR OF ENGINE 	WHITE 	A 	N/A
1990 	3.1L 	DIS IGNITION MODULE 	UNDER IGNITION COILS 	BLACK/WHITE STRIPE 	C 	N/A
1991 	2.2L 	DIS IGNITION MODULE 	REAR OF ENGINE 	BLACK/WHITE STRIPE 	A 	N/A
1991-94 	3.1L 	DIS IGNITION MODULE 	UNDER IGNITION COILS 	WHITE 	C 	N/A
1992-93 	2.2L 	DIS IGNITION MODULE 	REAR OF ENGINE 	WHITE 	A 	N/A
1994 	2.2L 	ENGINE CONTROL MODULE 	BEHIND PASSENGER SIDE OF DASH 	WHITE 	B11 	N/A
1995 	2.2L 	IGNITION MODULE 	REAR OF ENGINE 	WHITE & ORANGE 	E & D 	CP7558
1995 	2.3L 	DIS IGNITION MODULE 	REAR OF ENGINE 	WHITE & ORANGE 	A & B 	CP7558
1996-01 	2.2L 	IGNITION MODULE 	REAR OF ENGINE 	WHITE & ORANGE 	B & C 	CP7558
1996 	2.4L 	POWERTRAIN CONTROL MODULE 	PASSENGER SIDE FRONT FENDER WELL 	WHITE IN CONNECTOR 2 	20 	N/A
1997 	2.4L 	POWERTRAIN CONTROL MODULE 	PASSENGER SIDE FRONT FENDER WELL 	WHITE IN CONNECTOR 2 	10 	N/A
1999 	2.4L 	POWERTRAIN CONTROL MODULE 	PASSENGER SIDE FRONT FENDER WELL 	WHITE IN CONNECTOR 2 	10 	N/A
2000-01 	2.4L 	IGNITION MODULE 	TOP OF ENGINE 	WHITE & ORANGE 	A & B 	CP7558
I Just Got Mine Hooked Up...!! I Like!!
Jeremy Hayward
Wisconsin J!
1992 Chevy Cavy
Blisten Plug Wires, Bouche Plat 2 Plugs, Optima Battery, Sony Deck, Painted Dash, Painted Valve Cover
Future - New Doors, Rocker Panels, Drift Body Kit, 18's, System, And Maybe A New Turbo Motor When I Get Cash
Btchinj@hotmail.com & Btchinj@yahoo.com
