is this bad? i need to know
theres one on my other post
Rebuild pics!!!!
could use a good cleaning and maybe some new valves <since you said in the other post it was running 3 out 4> and mild deck job in order to clean up the gasket surface area <unless its not warped that much>.   if you are taking into a shop ask them test the head for cracks <minor ones sometimes are VERY hard to see>  If there was water in the cyl that stopped firing i would also replace the bottom ends main and rod bearings.
I took the pan of and no water in the oil. the car has a bad coil pack fo a while so i guess that why the 4 cyl was gettin no spark.
oh ok i would still clean up the head and valves though <maybe even new ones with springs depending on miles>.  and have them check for cracks also since you have it off already anyhow
mike i pland on i its going up the street tomorow. Its good have ing a machine shop up the street. it only has
90303 on it so i guess ill have the valves and springs changed
thanks again mike
