so the bulb fell out and i dunno how to take off that little clear plastic piece, so i need some1 to tell me how to take it off without breaking it. I would try it on my own but i did that in my 1995 cav and broke the little plastic pieces that hold it up.
Squeeze the sides together and pull it straight down.
i will try it thanks, do u know if there is any interchangable parts from a 95 Z24 cav to a 2.2 94 cav?
Seats, center console, wheels, thats about it...you can do more, but it requires either swapping out the entire area around it, or a lot of fabrication...
how about automatic windows?
Yeah motors and all should be a direct swap...well, maybe not direct, but should be able to be done with minor fabrication!
rear brake assembly is all the same as well as rear wheel bearings, calipers and rotors are also the same.
i switch the seats and then i realized a little problem.  The seat bealt doesn't fit, the driver seat buckle is attaced to the seat and my 94 seatbelt is to big for the buckle from the 95. So i am going to probably switch them back.
Why dont you just detach the buckle from the seat and bolt it into the car and use it like that?
i thought about it but now i am just like forget it, so i switched the seats back, and the stock seats are lil more comfortable
