The alternator on my 91 sunbird 2.0L quit charging.  So I replaced it with a new one and it's still not charging.  Battery voltage with engine off is 12.5V.  Battery voltage with engine running is 12.3V.  Got the new alternator tested and it's fine.  The battery tested good as well.  Any ideas on where to look?  I"m guessing that it's a wiring problem.
Fuseable link on the starter.
arch wrote:pezed, I'm diggin the new sig.  change is good
Thanks i made it myself!  Hopefully i'll have to make a new one soon when i get the Z24 GFX put on
Where abouts is this fusable link located?  Is it where the red battery cable bolts onto the starter?
Yep, you should see a strip of metal between where the alternator wire and battery cable connects.
