so i have 3 codes on my computer and they are
24-VSS circuit-Fault in this circuit should be indicated only while the vehicle is in motion. Disregard code 24 if set when drive wheels are not turning. Check connections at the ECM. Check the TPS setting....i know my VSS is screwed up as its not even hooked up due to that fact that i swapped trannys acouple weeks ago and the new 1 is a electronic speedo where as the old 1 was a cable drivin 1
33-MAP Sensor-Check vacuum hose(s) from MAP sensor. Check electrical connections at the ECM. Replace MAP sensor
45-Rich Exhaust-Check for a sticking M/C solenoid. Check wiring at M/C solenoid connector. Check the evaporative charcoal canister and its components for the presence of fuel. Check for fuel contaminated oil. Check the fuel pressure regulator. Check for a leaking fuel injector. Check for a sticking EGR valve. Replace the oxygen sensor
im gonna check the vacum line to the MAP AGAIN! and if it looks fine im gonna swap hte 1 i ahve from my 3400 sittin at my place,its alot newer so its worth a shot i guess,i also have the IAC from the 3400 that i mgiht put in
anyone think this would cause my car to stall out when i put it in nutral while coming to a stop?it usually only stalls if im at a higher speed or higher RPM,also sometimes it jsut goes down to 200-500RPMS then comes back to around 900 and if i tap the gas as im slowing down its usually ok
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Mike,
The book you're using for a code reference is a little old.  GM used the m/c solenoid in carbureted cars from about 1980 to around 1986.  You might find that a book for fuel injected vehicles is more helpful.
You should diagnose and repair codes in order from lowest to highest.  They're set up such that the higher code can be caused by what happens when the lower code is set.  I'll bet that code 45, rich exhaust, is caused by the MAP value being out of spec.  The MAP issue, of course, causes code 33.
It's very, very possible that these codes are causing a stalling issue.  Determine why the MAP code sets, and repair the VSS problem, and you should be ok.
hth
-->Slow
