I smell a rear disc brake swap
 I was planning on using shadow rear discs, I've been doing some research and it looks almost bolt on there is just one part that has to be slightly modified, but I'm pretty sure it will work.
Good luck with the swap, be sure to post lots of pics when your done
Neon rear swap.... Now what larger disks are you going to be using? Those look like 92+ calipers.
<img src="http://boner.berettaspeed.com/cavysig.jpg">
Larger front discs... and maybe moving the engine about 6" back for even better weight distribution.
-->Slow
Thats a 93 Bonneville caliper (same parts as the STS swap, its common to quite a few cars, including F bodies), but I'm going to be using the factory J bearing and machining the spindle to maintain the 5x100 pattern.
I wish I could move the engine back.
  After I get the new suspension in (coil-overs in front and adjustable perches out back. Konis all around), I'll cornerweight it for a little bit more of an edge.
machining... is in griding with an angle grinder like the wilwood install? Or actually using a fancy cutting / metal working machine.
CNC lathe and three axis milling. Fancy stuff.
Yeah its nice having access to all that isnt it
I've been looking for bigger front brakes for a while now, How big are the bonneville brakes? And what the rear brakes from?
James Cahill wrote:Thats a 93 Bonneville caliper (same parts as the STS swap, its common to quite a few cars, including F bodies), but I'm going to be using the factory J bearing and machining the spindle to maintain the 5x100 pattern.
So are you going to be attaching the Jbody hub to the STS knuckle?  Or retaining the jbody knuckle and installing the larger calipers?
And what are you plans for rotors??
I'll be using the J bearing on the STS knuckle. All it really needs to work is a sleeve to make up the difference in bearing diameter and three new holes for the bolts.
I'll be using Hawk HPS pads and Brembo rotors all around. Check out my new post for more info.
