Your old springs were shot.
When in doupt, grub.
eiback=.8" drop, so if your stockers were saggin more than an inch, it will be noticable. the eiback springs are progressive, so the coils get closer together at the top. the only thing that is important is the overall hight of the stock and eiback springs, the eibacks should be just a bit shorter.
if they raised your car 3-4", you installed them wrong. make sure they arent hanging up on the nub on the axle.
Yeh eibachs raised the back of my car maybe 1/4" but i like it better that way.  I like the car to sit even, not the rear lower than the front.
(stock springs had the rear tire tucking under the fender)
u did somethig wrong, or put the fronts on the back.
-Borsty
Eibachs have more coils in the back .. this is so they will be stiffer and stop the car from bucking back when you get on the gas like the stock springs do.  With the eibachs you should have about a 1/2" gap between your back tire and fender, if not, something is wrong with the install.  Make sure you have the bottom bump stop seated right.  make sure the spring coil end is up against the spring stop on the top .. or else it wont seat right. (yes there is a correct way the springs need to be turned in the seats for them to sit right, i didn't realise this until i had my shocks already installed
I'll crawl under and look at my car in a minute but those numbers seem right to me from memory.
Here is a pic of how it sits with the springs:
your not gonna notice a dramatic lowering in the frist day or two.
give them a few days in the sun and driving on and you'll notice them to settle down.
Have you tried taking the shocks out and seeing how it sits?  don';t drive it like that of course.
Get a pic, we need to see this
put some mudders on it, and go 4x4ing. lol.
that's high yo!
Those are definetely not the right springs. The correct Eibachs only have 2 or 3 high rate coils, not 5 like those. Those could be L or N body springs.
Listening in - I'm doing my install and have the same springs so...
