will the stock gm z24 strut bar bolt up to the 4 cyl cars
Only if the same phase....PH2s going onto a PH1 and vice versa require new holes to be drilled...
89Sunbird wrote:Only if the same phase....PH2s going onto a PH1 and vice versa require new holes to be drilled...
Partially correct.  The bolt pattern on the strut mounts changed in 92.  91 and older use the same style mounting pattern.   What year is the car and what year is the bar from?
http://cavalierman93.googlepages.com/
well there was a 88 at my junkyard with one on it and my car is a 90, so im guessing it'll work
Yeah that'll be a direct bolt on, literally!
