where can i find the list of codes for the check engine light....i know how to make it read off the codes but i dont know what the codes are.....mine is flashing code 41 if anyone knows what that means?
according to my manual, Code 41 (4 flashes, pause, 1 flash) Code 41 is Cylinder select error.
fix:
Remove the acess cover on the ECM and check to see that the MEM-CAL, PROM, or CALPAK, is installed properly. Clear the trouble code and see if the code resets. If so, Replace the MEM-CAL, PROM, or CALPAK.
there's also another one for code 41.
here it is:
No distributor refernce singal to EXM at specified vacuum. (carb. only)
Fix:
Check all wires and connections at the distributor. Check the distrubtor pick-up coil connections. Check vacuum sensor circuit.
hope that helps...
basicly you either have a bad ECU, or bad Distrubitor.
What is the car doing? what year, model, make, motor, trans? need more info yo!
