I have a stock 92' Cavalier with the 2.2 OHV engine that needs a lot of TLC. I've considered having the entire engine replaced instead of flinging parts into the old one. Now, had I the tools and time I'd very much enjoy doing it myself but that is not the case.
So my question to the pro's here is this. Which engine would best increase performance while being relatively quick to install? I have to consider labour costs so the easier the better. Its also an automatic.
T.I.A. to all suggestions and opinions.
actuly the 2.3 qaud4 was rated at 180hp and the 3100 is only rated at 150hp. im not sure how simple the quad4 swap is but i've seen people do it befor with good results.
I like the idea of the 3.1. Should run much smoother with a v6 as well. Looks can come later I want more power first
Will the automatic trany be a problem?  What about wiring and the Rad?
ahhhh the 2.3 is a big ol pile o' monkey poo. its definately good for power but to work on suck. i'd prolly go with a 3.1
nothing
2.0 Turbo was the quickiest cavalier production car. STOCK. 15.4 on a 5spd. STOCK!
however, i like the quad 4 motor. strong, quick, and torquey.
Evan Griggs wrote:actuly the 2.3 qaud4 was rated at 180hp and the 3100 is only rated at 150hp. im not sure how simple the quad4 swap is but i've seen people do it befor with good results.
no kidding.
<a href="http://www.j-body.org/members/speedvisioncavalier"><img src="http://www.j-body.org/registry/speedvisioncavalier/new%20sig.jpg"> </a><img src="http://www.precizion.org/animatedz.gif">
"What are we going to do tonight?"
"The same thing we do every night, try to make the SVC go faster!"
SunValier wrote:2.0 Turbo was the quickiest cavalier production car. STOCK. 15.4 on a 5spd. STOCK!
yea, but if you look at the olds calais 442 W41 (N body), they were able to pull 14.6 times STOCK on a 5 speed. those calais weighed the same as the Jbodies. much better motor.
3400 sfi would prolly be the best reasonable swap.
you could go with the 3800 s/c but that would involve alot more work meaning that its a much larger motor (3.1/3100/3400 are all 60 degree Vs and the 3800 is a 90 degree V). you would also need the ecm and harness from the 3800. im sure there is also more stuff needed to do the swap, i just cant think of them right off the top of my head....im still a noob.
Speed costs money, how fast do you want to go?
You're gonna need the wiring harness and ecm whether you go with the 3.1, 3100, 3400, or the 3800.
I understand that I'll need wiring and I think i'll install an independent tach instead of a new gauge cluster.
My biggest fear is the transmission. Can anyone tell me which of these engines will bolt up to an automatic, if any?
I don't mind standard but I'm not the only driver.
the 3.1 is a direct bolt on. or so I've heard.
2009 Ford Mustang V6
depending on your budget, I'd either reccomend a 3.1 L swap or a 3400 swap. expect to pay around 4-600 more in parts for a 3400 swap (mount and exhaust and a few other things are different.)
your auto tranny will bolt to both the 3.1 and the 3400 no problem.
___________________________________________
1989 3.1/3400 hybrid Nitrous fed Z24.
14.13@96.69 mph  full interior, N/A
(still haven't sprayed at the track)
Perfect. Thats what I wanted to know. There's a shop in my area that will give me a good deal on labour and parts. I'll have them look into the 3.1 for me including the harness and ecm.
Thanks guys. I'll let you know how it goes.
