I was just wondering if there is difference between '92 block and pre-'92 block. I am asking becuase I found 90 block that need s a new head, if it wass the same I would rebuild the engine then put my mpfi head and intake. Thanks
Check out the post called "FAQ site" and look for the 2.2 history link.
The site doesn't work. and my engine is 2.0 ohc
pre '92 2.0 no crank position sensor, so only 92-94 block will interchange. Just in case someone else cares.
AM I RETARDED or AM I JUST OVER JOYED?
