turbo thermostat housing needed - First Generation Forum
Monday, September 06, 2010 12:44 AM
Hi anyone have a thermostat housing for a sunbird with the watercooled turbo? I'm replacing the turbo, the new one is water cooled and unless I'm wrong, all I'll need to upgrade it is a new thermostat housing with the water fittings...does that sound right?
FYI it's an '86 turbo convertible
Re: turbo thermostat housing needed
Tuesday, September 07, 2010 6:38 PM
Hey Chad-
The t-stat only gets you 1/2 way there. You also need to t-into another line for the coolant flo-through. I still have the oil cooled only so can't help with the routing.
I will keep my eyes open, but the turbo cars are not showing up much now...
Tuesday, September 07, 2010 10:09 PM
Ron Love Online
Check out the site I will list they carry the thermostat housing for your year and engine for 72.00.This is a oem gm part no bs. http://www.chevroletpartscenter.com
Wednesday, September 08, 2010 5:24 AM
Chad, your profile doesn't show a location... PM me with your zippy, and i'll be able to estimate the cost for the ride.
A thought.... when changing to a larger turbo, the steel tubing x-mani is marginal strengthwise at best. Best to use the cast iron version. While this will give you added strength, it will also relocate the turbo up & downpipes, so diff ones are required. There's a post I made, several times, about exactly what's needed, and the angles that are changed in setup.
Hope this helps.................. Alan
