alright I figured I might get a better response here. I tore down the motor last year never got back to putting it all back together cause of getting married and then getting divorced and other stuff. But i'm having an issue remember where the metal lines go. any help would be appreciated figure i see pics i will remember and have a reference to look at
Well...
I dont have any pics of the motor you could use- but I know the motor itself pretty damn well...
The only hard line I can think of that
wouldn't be obvious where they went would be the hard coolant line.
It comes off the back of the water neck right at the head near the power steering pump. Theres a small bracket on the line that gets bolted to the end of the cam tower. It bends 90 degrees and runs along the top of the exhaust manifold. The bracket on the line bolts to one of the manifold bolts... Then it just runs to the nipple on the coolant reservoir (the back nipple).
If you could be more specific as to what lines you are having trouble with, I'm sure we could tell you where they go...
i can get pics here in a little bit. what angles do you need?
I have the black coolant line and a silver hardline. It was the black coolant line that i couldn't remember how it went and I also had a gasket that I couldn't figure out where it went. I will get a pic of the gasket tonight probably a front shot, over top shot and possibly one of the exhaust side. I will also snap pics of the lines. i hated doing it how I did it but sorta got stuck doing it that way.
