I'm looking for the dimmer with the fog light panel.. fog light switch has to have the pigtail.
http://www.jbodytuner.com
^^ The real jbody store and forums!!!!!
Just a tip if you adding foglight to a car that did not have them you need the 95-99 switch because its an acutual switch, 00+ just triggers the bcm and the bcm does the dirty work.
even if you are replacing a switch make sure to get it from the right year car. oh yea and my 99 dimmer switch (for the gauges) did not work on my 02 wiring
junkyard is best bet
My car may run 18s, but I can do your taxes in 10 seconds flat.
JBO lube - they would never have enough in stock and we'd never see RodimusPrime again
I have one of those lying around SOMEWHERE...haven't seen it for a few years, though. I'm about to buy some turn signals for a 95-99 GT from a wrecking yard. I'll see if they have the rest of the car, too.
okay thanks.. i guess i need the 95-99 switch as i added fogs..
^^ The real jbody store!!!!!
any luck guys?
still need one.
I have a switch from a 96' Z.... but no pigtails. PM me if your interested.
