Hello and good day to all. It's coming closer to the time where the temple of boom will be restored, and I need some bigger amps.
We'll start with a pair of sub amps.I have 2 HK401SX amplifiers. I'm the original and only owner. These amps were not clipped nor undervolted. As most of you know I'm good with audio equipment, so these amps were not abused in the least. Here's the specs:
1800W RMS 1 Channel High Current Amplifier
500W RMS @ 4 Ohm Mono
650W RMS @ 2 Ohm Mono
1200W RMS @ 1 Ohm Mono
1800W RMS @ 0.5 Ohm Mono
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
Quiet Fan Cooling System
High Quality Power & Protection LED’s
Thermal / Short / Overload Protection Circuitry
0-18 dB Variable Bass Boost
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
24dB Subsonic Filter
Remote Bass Control
THD @ 4 Ohms <0.05%
THD @ 2 Ohms <0.1%
THD @ 1 Ohm <1.0%
S/N Ratio: >90dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
Input Voltage Range: 200mV - 8V
Input Impedance: 10k Ohms
Dimensions: 2.7" H x 12.4" W x 10.6" L
It has 1/0 inputs and 8 gauge speaker inputs.
I'll do 200 local pickup each, 375 for the pair local pickup. I do have boxes/bass knobs n'at.
Next is my 4 channel amp. It's an MA Audio M500XE. Again, I'm the only owner.
4 Channel High Performance Amplifier
4, 3, or 2 Channel Operation
1000 Watts Power Output
500 Watts x 2 Channels @ 4 Ohm Bridged
225W RMS x 4 Channels @ 2 Ohm Stereo
125W RMS x 4 Channels @ 4 Ohm Stereo
Selectable LPF/FULL/HPF Crossover
Variable High Pass Crossover Frequency: 50Hz-250Hz
Variable Low Pass Crossover Frequency: 50Hz-250Hz
Variable Bass Boost 0-18dB @ 45Hz
Adjustable Gain Control
3-Way Protection Circuitry (Short/Overload/Thermal)
Power and Protection LED Indicators
Full MOSFET Circuitry
High Level Speaker Line Input
Low Level RCA Input
2 Ohm Stereo Stable
Mounting Hardware Included
Dimensions (L x W x H): 13" x 10" x 2"
Looking at 100 dollars picked up for this gem.
If you want all three amps, I could do it for 450 local pickup.
LMK.
Well, I am in the market for a new amplification package.
What do you have that will nicely drive the 4 10's i just picked up?
Aluminum coned eclipse......i will have model number and specs later tonight.
Im looking for something to push them, but not needing to push them to thier limits.
Also, I know these are prolly the ones that we took out when I was there....but pics??
Alright, looks like the 4 channel amp should be sold Friday.
Lanman31337 - Cavfire wrote:Alright, looks like the 4 channel amp should be sold Friday.
i want a biggun and the 4 channel if it is still around.
I still have the two big ones.
damn I coulda used that 4 chan
LE61T PTE6262 Powered
sorry i already got dibs on the 4 channel
I *think* Benham wants one of the HK's so someone please buy the other one so I can go 6000+ rms!!!
yes, ill take one of the bigguns, hit me up about payment.
Of course that puts me in the same boat....gotta sell mine now to.
But yeah, mark me down for a big guy, and possibly what we had discussed earlier......in private
Free gift with each amp!!!!!!!! I pick the gift!!!!!!!!
i might be interested in the big one left. My girl wants a system in her jeep so. Hey sometime we need to meet up so you can get this dash from me man.
Word. PM sent. And i'm going to pick up a dash tomorrow.
Two big amps left still, I put them on craigslist and had a hit already. I'd much rather sell them to .org members. BUY MY PETRIFIED MEAT!
you know im down for one.
Have the monies and everything now. Just have to get together, and the sick boy is making that very hard. Which is why I can come down this weekend to help run wire too : (
Right on. I was holding yours, no problems with that my friend.
