Built & Turbo OHV Cav For Sale & Part Out! - North East Region Forum
Monday, February 02, 2009 11:08 AM
So I've been doing some serious thinking and I am about 90% sure that I am going to leave the J scene. It is just not the best time in my life to have a project car. If I get enough interest on this car I believe my decision has been made.
I will part it completly out but if someone wants to finish my nearly done project than I would love to see that happen.
2002 LS Cavalier - I am the second owner, I have owned it since 2004. Clean vin, never been in an accident. It now has a 95-00 Sunfire front end conversion with evil eyes welded on an oem hood & an RK Sport Sunfighter front bumper.
Best offer on everything unless I put a price.
What can be parted out...
Exterior
*95-99 Z24 rear bumper & side skirts - Freshly painted Indigo Blue & never been installed - $100 OBO
*Shaved fiberglass trunk (4 small holes on it for where SS wing sat) - BO
Turbo Stuff
T3/T04B Turbocharger (48a/r - turbine & 70a/r - compressor) w/ stage3 wheel
Tial 38mm External Wastegate (if you want custom atmospheric dump tube you can have for free with it cause it may or may not work in certain setups)
Turbo Exhaust Header
Turbo XS Intercooler
Golden Eagle Vacuum Manifold
Stainless Steel Oil Feed line
Oil Filter Sandwich
2.5" Charge Pipes
Tullos Technology Electronic Boost Controller
2.5" Custom Exhaust & Down Pipe
Magnaflow High Flow Catalytic Converter
Vibrant 12" Resonator
Engine
I have two heads one is completly stock and I can put that back on the car, The other has - Howell Automotive Pushrods, Cromoly Locks & Retainers, Port & Polished Head, Stainless Steel Valves, 5 Angle Valve Job, JBP valvesprings
The block has - JBP Turbo Camshaft, V-8 Spring Swapped Lifters, M98 Oil pump
Wiseco forged pistons (stock compression & stock bore) & Eagle rods - brand new/never ran but assembled and ready to drop in - $600 OBO
Misc
I also have a couple glow-shift gauges - boost, oil temp, oil pressure, fuel pressure (still have the lil plastic/stick protectors on the gauge face)
Walbro 255 w/install kit sitting waiting to go in
Upper engine mount insert
Spare .30 cometic head gasket, new in box. - $75 OBO
The car just needs an alternator which I will install and it will run like a charm. Turbo'd or not. I can revert it back to stock, including the stock head if wanted. I dont want to pull the block so it will be runnig with a cam thats a bit more agressive than stock as well as the stronger lifters and a better oil pump. But other than that I can put it back to a stock car and that would give u an engine with 57k miles and a stock head with mid 40k mileage (the modified head has low 50k mileage). I can supply a stock camshift with a few other stock components I have laying around as well.
If you want to pick up where I left off. The car will easily run 15-20 psi (if you tune it right) with the pistons and rods if you install them.
This car is fast running at 9 psi on the stock pistons and rods estimated 250-300 hp/tq at the wheels.
I love this car so much but I just dont have the the time or place for a project right now.
Edited 3 time(s). Last edited Monday, February 02, 2009 11:14 AM
Re: Built & Turbo OHV Cav Part Out!
Monday, February 02, 2009 11:13 AM
toss up some pics chica
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Monday, February 02, 2009 11:20 AM
I dont have any good ones here at work, but here are some recent ones - (Don't mind how dirty it is)
Also don't mind the wing, it's stock trunk is going back on which has the 00-02 lS wing/95-99 z24 wing.
Edited 1 time(s). Last edited Monday, February 02, 2009 11:28 AM
PICT00101010 copy1.JPG (57k)
Sorry but 250-300whp on psi? Thats hard to do even with an Ld9/L61.
Good luck with the sale part out though. Wish you were a 2.4
Monday, February 02, 2009 11:21 AM
BOOO!!!!
you suck big ugly minkey nuts.
(give me your vaccum manifold)
BOOO!!!!
Monday, February 02, 2009 11:22 AM
icemike89 wrote:Sorry but 250-300whp on psi? Thats hard to do even with an Ld9/L61.
Very similar build to Imphat0260 and he ran around 280 at the wheels on his at 9psi on the T3/T4 - Like I said, its estimated. It's never been on a dyno nor on the track.
Monday, February 02, 2009 11:33 AM
he must never have been in a well done turbo setup on the ol OHV.
Edited 1 time(s). Last edited Monday, February 02, 2009 11:35 AM
Monday, February 02, 2009 11:39 AM
if i buy the whole car do you come with it?
Monday, February 02, 2009 11:46 AM
No,but Ive been in eco's and ld9's with well done turbo setups that werent making that power. Especialy on stock motor and only 9psi? And only using lsj injectors correct? Im not argueing anything saying its not possible, but thats a little steep of a number to just guess on even comparing to a similar setup. Anyways, Im not trying to jack this thread all up just stating my opinion.
You selling the innovate wb jazer? If so what model?
Monday, February 02, 2009 11:52 AM
icemike - Not a stock motor... Completly built asside from the pistons and rods that are waiting to go in. If I tuned it as good as Ryan is a tuner, I was running in the same power range as he was was before I put the cam in... and I noticed a decent gain in power once I did that, so It was even more. This car is NOT slow at all. Im not trying to brag but if you get on it you better have a hard hand on the wheel. The butt dyno tells all
It's an Innovate LC1. Yes I suppose that needs to go too but its technically my BF's so Ill ask him.
Sorry AWD GS - no I do not come with the car
Monday, February 02, 2009 11:56 AM
Jazer Esquire wrote:Sorry AWD GS - no I do not come with the car
welp way to ruin my afternoon lol
gl with the sale
Monday, February 02, 2009 12:18 PM
hell I was at 14 psi with cams and built motor on an eco and only at 300 whppp
get it on a dyno, then sell it
LE61T PTE6262 Powered
Monday, February 02, 2009 12:23 PM
gay cough
Monday, February 02, 2009 12:25 PM
There are many factors to take into consideration. PSI is no gauge without the turbo size.
This is not what this thread is for anyways. I am not here to defend anything.
I want to find a new home for my car & my parts. That is all.
jeremy carlin (cavguru) wrote:gay cough
shut up Jer, lol
Edited 1 time(s). Last edited Monday, February 02, 2009 12:26 PM
Monday, February 02, 2009 7:11 PM
throw out a price on the turbo and wastegate.
Monday, February 02, 2009 9:15 PM
how much do you want for the whole car?
Tuesday, February 03, 2009 6:04 AM
For the whole car with everything I have for it, including a stock head, spare cometic head gasket, etc, I am starting the 'bid' around 6k. There is a lot of money invested into the motor/turbo parts.
I have some interest in the car as is, If I part it out, for the Turbo and Wastegate, i donno... 400$
I will meet someone a good distance if they take the car as a whole. I really want to see it go to someone who will finish the project. It is so close to being a very strong OHV capable of high numbers.
Edited 1 time(s). Last edited Tuesday, February 03, 2009 6:05 AM
Tuesday, February 03, 2009 9:11 AM
wow, didn't see that coming.
GLWS
Tuesday, February 03, 2009 10:56 AM
My BFwill sell his HPT Pro as well since we will no longer be tuning GM vehicles - 500$
Tuesday, February 03, 2009 11:06 AM
SOOOO, u gunna tell us WTF happened to cause all this???
Tuesday, February 03, 2009 11:07 AM
John Benham wrote:SOOOO, u gunna tell us WTF happened to cause all this???
she's joining the circus
Tuesday, February 03, 2009 11:49 AM
oooo, I hope a contortionist in a nudist circus.
Ill go to that circus.
Tuesday, February 03, 2009 11:58 AM
Looks like all the big 2.2l builds are getting out of it! I too am parting my cav out!!! good luck with everything
Tuesday, February 03, 2009 12:32 PM
John, I think you are familiar with my situation. I hate to give up on it but without owning my own house I dont have a garage to store it and work on it which makes having a project-type car much more difficult. I just don't have the time or money right now to be in the middle of a project. There is still so much left in my eyes to get it where I want it that I just can't be doing this at this point in my life. I HATE to give it up, it will break my heart getting rid of it, but it is just something I need to do
Tuesday, February 03, 2009 12:40 PM
How about tucking it away for a while? There is no law that says you have to work on all the time.
Hell it has been almost 2 years since i touched my truck.
Tinkles
v. intr.
1. To make light metallic sounds, as those of a small bell.
2. Informal To urinate.
v. tr.
1. To cause to tinkle.
2. To signal or call by tinkling.
n.
1. A light, clear metallic sound or a sound suggestive of it.
2. An act or instance of tinkling.
