What size sway bar would be best for all year round handling? Michigan gets snow, and I know if I get a sway bar that's too big it will cause the car to slide if its too stiff. Also is 18x7.5 a good fit with a 1.5" lowering springs for the z24 without causing inner wear on the front tires? Will that size wheel be flush with the wheel wall?
The Eibach kit is fine for year round driving in Michigan. What is the offset on the wheels you will be using, and what sized tires?
and inner wear on the front tires indicates an alignment issue, not a wrong sized tire/wheel
