To start the story i will tell u why im selling it...
About a month ago i was at my buddys and my car started making a weird noise and i had it looked at and was told it was a lifter problem (not 100% for sure, have not tore into it and found out). The car has pretty muchbeen sitting eccept for the 1 hr ride to bardstown and bac and occasionla trip to PT and back. and its still running GREAT .bosting normally and everything(supercharger has less than 500 miles on it).
And due to wanting to start a new project (ECOTEC with a couple plans in store for it) i am going to sell this thing as a whole(will seperate if i can find someone to buy the 2.4 and s/c ) . i have had it looked at by bob hook and they said either a lifter or rod bearing ..and had it looked at by a couple good friends and they all said lifter..
I would like to sell both for $ 2,100 ..(PICK UP ONLY) this price inclued everything with s/c motor (upper insert..lower mount .everything) OBO
MSG me on here or AIM ir wizlock23...or email wizlock23@yahoo.com
What year is the car, and I may be interested in the harness and pcm if its 2000+
How much for the charger and everything that came with it...claps...hoses....injectors..bla bla
The charger and ALL everryhting it came with for. say 1400..It hasnt even been on for a couple months..LESS THAN 500 miles
or throw me a ofer..
Also, was his car a manual, or auto?
Ohhh sweet, keep me updated if you guys decide to do the eco swap, ill gladly take the harness, pcm, map sensor...
im 100% for sure doing it..
i got some plans in store gonna take place during this winter
lil bit at a time till i get it all bought ...
But right now i need to sell the 2.4 and S/C
any offers?!
How much for just the motor? I'm looking for a block
2000 Camaro V6.
psh I have no clue I'm no good a this
2000 Camaro V6.
Im trying to think of a good price..it only has 60k on the motor.. make a offer and we will start from there
WhininZ wrote:How much for just the motor? I'm looking for a block
I have a 02' short block with bottom end...30,000 on it. I'll let go for $250.
GM PART # 12498660
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $1,929.00
OUR PRICE: $1,404.31
1400 is brand new price......would you take $1000?
David I want the map.
Well the S/C JUST got put on not even a couple months now...NOT even 500 miles...its still brand new pretty much..and i apid 1600 with sipping ..
how bout 1250?
Still up for grabs..Offers .
if white cavy changes his mind on the pcm, I want it
Hum 1250....... would you meet me half way. I live in Madison, Ohio 44057
I think it would be about 6 hours total time....so three each.
Or would shipping it be better.
Also, low on cash so it would be a few weeks.
Thats cool, im tracking a ecotec down right know so as soon as i find one i will let u know, and i can meet u somewere in between if u want...
everything else up for sale...
post what u need and we can work out a price
Yeah, meet down here in Columbus
Mike, if your getting the charger then yea thats cool.. Take the MAP.
Ill back out of this one, not really sure if I want to mess with the 00+ harness swap right now.
2012 numbers - 4SPD
AUTOMATIC!!
David its only a few wires.
^^Mannn, i keep hearing so many different stories on that..
I heard
Its the fuel tank, the evap system, the complete engine and body wiring harness, and the cluster..
Then you tell me its just a few wires! lololol
I was joking. It aint that easy. Better of finding wretched 00-02.
You need PCM, BCM, Whole body harness...or most of it, Evap not sure, cluster is a must.....then you need the whole 00-02 dash unless you can figure out how to get a 2000+ cluster in your 99-95 dash. You engine is good to go because it is wired for the 99. Everything you did to make your car run the 2.4.....you have to almost do again.
Or you can go wire happy with your old cluster. Trying to find the 99 pinouts I have....
2.4 2000+ ECM pinouts
Pin Color Circuit No. Function
1-5 -- -- Not Used
6 BLK 2759 Fuel Tank Pressure Sensor Ground
7 BRN/WHT 633 CMP Sensor Signal
8 PPL/WHT 430 CKP 7x Reference Signal
9 -- -- Not Used
10 GRY 2709 Fuel Tank Pressure Sensor 5 Volt Reference
11-17 -- -- Not Used
18 BLK/WHT 451 PCM Ground
19 PNK 639 Ignition Positive Voltage (2)
20 ORN 480 Battery Positive Voltage (B+)
21 DK BLU 417 TP Sensor Signal
22-24 -- -- Not Used
25 ORN 406 Ignition Control Output 2-3
26 WHT 423 Ignition Control Output 1-4
27 TAN/BLK 231 Engine Oil Pressure Sensor Signal
28 RED 1226 Transaxle Range C Input
29 BLK/WHT 771 TR Switch Input A
30-31 -- -- Not Used
32 GRY 1716 Knock Sensor (KS) Reference Low
33 -- -- Not Used
34 DK BLU 496 Knock Sensor (KS) Signal
35 PPL 420 TCC Brake Switch Input
36-44 -- -- Not Used
45 DK GRN 890 Fuel Tank Pressure Sensor Signal
46 YEL/BLK 1227 TFT Sensor Signal
47-48 -- -- Not Used
49 RED/BLK 380 A/C Refrigerant Pressure Sensor Signal
50-51 -- -- Not Used
52 BLK 552 A/C Refrigerant Pressure Sensor Ground
53 GRY 23 Generator Terminal F Input
54 YEL 410 ECT Sensor Signal
55 PPL 1589 Fuel Level Input 5 Volt Reference
56 -- -- Not Used
57 BLK 452 TP Sensor Ground
58 PPL 1807 Serial Data (Class 2)
59 PPL 1807 Serial Data (Class 2)
60 TAN/WHT 551 PCM Ground
61 -- -- Not Used
62 LT GRN 432 MAP Sensor Signal
63 RED/BLK 1230 A/T ISS Sensor High
64 PPL 401 VSS High
65-66 -- -- Not Used
67 DK BLU 1225 Transaxle Range B Input
68 PNK 1224 Transaxle Range A Input
69 YEL 772 TR Switch Input B
70-71 -- -- Not Used
72 GRY 773 TR Switch Input C
73 WHT 776 TR Switch Input P
74 RED 225 Generator Terminal L Output
75 BLK 1744 Fuel Injector #1 Driver
76 LTGR/BK 1745 Fuel Injector #2 Driver
77-80 -- -- Not Used
Powertrain Control Module (PCM) Connector C2 Black
Pin Wire Color Circuit No. Function
1-5 -- -- Not Used
6 RED/BLK 1228 PC Solenoid Valve High Control
7 -- -- Not Used
8 DKGR/WH 465 Fuel Pump Relay Control
9 LTBL/WH 1229 PC Solenoid Valve Low Control
10-13 -- -- Not Used
14 BLK/WHT 1704 MAP Sensor Ground
15 -- -- Not Used
16 DKGR/WH 817 VSS Output
17-19 -- -- Not Used
20 TAN 472 IAT Sensor Signal
21 TAN 413 O2S 1 Low
22 PPL 412 O2S 1 Signal
23 TAN/WHT 1669 HO2S 2 Low
24 PPL/WHT 1668 HO2S 2 Signal
25-26 -- -- Not Used
27 BRN 718 ECT Sensor Ground
28 GRY 720 IAT Sensor Ground
29 BLK 407 TFT Sensor Ground
30 -- -- Not Used
31 RED/BLK 453 ICM Reference Low
32 -- -- Not Used
33 GRY 416 TP Sensor 5 Volt Reference
34 GRY 596 A/C Refrigerant Pressure Sensor 5 Volt Reference
35 GRY 474 MAP Sensor 5 Volt Reference
36 RED 631 CMP Sensor Ignition Positive Voltage
37-44 -- -- Not Used
45 DK GRN 83 Cruise Disable Output
46 BRN/WHT 419 MIL Control
47 -- -- Not Used
48 LT BLU/BLK 396 Cruise Engaged Input
49 YEL 657 TCC Release Switch Input
50 -- -- Not Used
51 YEL/BLK 1223 2-3 SS Valve Control
52 -- -- Not Used
53 LT GRN 1222 1-2 SS Valve Control
54 DK GRN 335 Cooling Fan Relay Control
55 DKGR/WH 459 A/C Compressor Clutch Relay Control
56 DKGR/WH 428 EVAP Canister Purge Valve Driver
57 BRN 418 TCC PWM Solenoid Valve Control
58 WHT 1310 EVAP Canister Vent Solenoid Driver
59-60 -- -- Not Used
61 YEL 400 VSS Low
62 DKBL/WH 1231 A/T ISS Sensor Low
63 PNK/BLK 632 CMP Sensor Ground
64 BLK/WHT 451 PCM Ground
65-70 -- -- Not Used
71 LTBL/WH 1747 IAC Coil A High
72 LTGR/WH 1749 IAC Coil B High
73 LTGR/BLK 444 IAC Coil B Low
74 LTBL/BLK 1748 IAC Coil A Low
75 LTBL/BLK 844 Fuel Injector #4 Driver
76 PNK/BLK 1746 Fuel Injector #3 Driver
Edited 1 time(s). Last edited Wednesday, August 01, 2007 7:43 AM
Holy crap..
2012 numbers - 4SPD
AUTOMATIC!!
