Well I've been on the fence for a while on what I'm going to do with the car. Sell it as is, part it out, or just let it sit in my garage till I have time for it again. Being as im 30, and wanting to buy a bigger house, I've decided to part it out, put the car back to mostly stock, and sell it. I don't have pics of every part listed below but I'm still working on it (60 hour work weeks and two kids doesnt give one a lot of free time). My car is 02 cavalier with the ecotec motor. If you have any questions ask away. Prices do not reflect shipping prices. My zip is 45327. If you wanna look up the shipping cost. Big items are pick up only. Link to a lot of photos below and more pics and parts to come. Thanks guys
http://s1172.photobucket.com/albums/r578/bburkett00/
The parts;
-lotek triple pod, charcoal gray. $30
-rk upper motor mount $50
-rk lower motor mount $25
-aluminum tilt lever $20
-BEGI fmu- all diaphragms recently replaced $120
-rc 550cc injectors with harness-recently cleaned and flowed $200
-hks turbo timer $20
-borla xr1 3" in/out with dump $70
-lsj head gasket-new $60
-catch can-self made $40
-1 off custom made radio mount/gauge kit-modification need to work $40
-phantom boost gauge $25
-phantom egt (pyrometer) gauge $100
-phantom fuel pressure gauge-electronic $110
-racetronix fuel pump/harness/booster pump kit $125
-m/t slicks 24.5x8x15 mounted on 5x100 steelies $125
-front strut tower bar-self made $30
-rear strut tower bar-self made $30
-computer mount-self made $30
-turbocharged idi cover- $50
-supercharged idi cover-polished but now a few scuff from sitting around $100
-intake manifold-self made $300
-turbo kit- t3/t4 turbo has shaft play and was starting to smoke, turbo xs rfl bov, turbosmart 38mm waste gate, header, 3x6x29 intercooler, 2.5 to 3" collector down pipe, 2" ic piping to ic and 2.5" I've to tb. Ac would have to be removed to run the header and the windshield washer reservoir would need to be removed for ic piping $800
-engine- 2.2 ecotec-eagle h beam rods, wiseco .020 pistons, oringed block, sce copper head gasket, si 1mm oversized valves, ported and polished head, everything else is all factory parts. 22-23k miles. Was starting to have a problem and if interested in motor I will go in depth. $800
If your interested in custom aluminum tilt wheel levers hit me up!
Ok let me get into what the motor was doing before i parked the car. Everything with the motor was completely fine when I was running 8 psi. The after a few tuning sessions I had the car running 18psi. All was fine for a bit and then I noticed some chocolate milk like sludge in my coolant. Checked the dipstick and oil was same way. So I do I flushed the coolant system till clean and changed the oil and added a half court of tranny fluid to the oil(tranny fluid has a detergent in it that cleans the motor). Drove around for 50-100 miles then changed the oil again.
Took it easy on the car for a week or so while keeping a close eye on everything, and all seemed fine. Then after getting home one day while out doing some spirited driving I noticed the same thing. Milky coolant and oil.
Personally I think either my copper head gasket was leaking or with the boost I was causing the head to lift. I did a compression check on all cylinders. 1 2 and 3 all checked between 195-205. Cylinder 4 was at 175-180 but it was always lower even after doing the build back in the summer of 04.
Its been 2 years since this happened and Im just tired of the car taking up space in my garage.
Pics in the photobucket link provided but here ya go anyways
does the catch can have two large barb fittings like that one we can see?
Not just the two you see, but if you can weld aluminum I could possibly supply ya with another bung and fitting.
im possibly interested in motor
Built&Boosted moar
Ok just lmk. I also forgot to add the motor has arp head studs
Intake or exhaust? There are pics of both in the supplied link to photobucket
PM'ed! Interested in the slicks...
You got mail
I do? My inbox says I don't
Email or PM? PM works better..
Pm
I want the slicks! ^^^ if Alex gives up dibs. Hoping to hit auto x soon and I've got crappy steet tires. PM me in on my phone
I roll on steelies. Work-in-progress daily-sleeper potential.
http://www.j-body.org/classifieds/engine/60493/
Weffy wrote:I want the slicks! ^^^ if Alex gives up dibs. Hoping to hit auto x soon and I've got crappy steet tires. PM me in on my phone
The slicks are for drag racing not auto x
Replied to all
Parts that have sold and shipped;
Msd box
Racetronix fuel pump
Tilt lever
Turbo timer
Slicks
Boost gauge
Would you be willing to throw the lower mount in a flat rate box usps?
SLOCAV wrote:Would you be willing to throw the lower mount in a flat rate box usps?
Yes I can.
boostedeco wrote:Intake or exhaust? There are pics of both in the supplied link to photobucket
My A/C blows ice cold! I have a manifold from a saab 9-3 for now. You say the turbocharger was starting to smoke? I definitely want the charge piping, IC, bov, wastegate, all those goodies. I sorta kinda want your engine too. You also said your returning this to stock? I've got a stock 2.2 motor with 90k, clean as a whistle if your interested in a package-mega-deal/trade thingy.
Yes I'm returning in to mostly stock. Leaving the wheels, coil overs, and a few other things on the car since I think it will help sell the car. I just went last weekend and bought a motor with 25k miles. Yes the turbo was starting to smoke and has shaft play. I'm sure I could sell the turbo header seperate if you didn't want that. But I can work out a deal with ya if you want the motor and turbo stuff
Added a few more pics of the engine, head, front and rear strut tower braces. May also be adding a b&m short shifter to the list if I get a stock unit
Got the slicks today! Thanks bud! Excellant seller guys! A++++
