Thinking of going a different route now
PM or email me    Email is in profile
I will either strip the car right down to nothing if there interest that way or sell the Car itself with Motor Mods and such for a price
Here is what im thinking
First up
2000 Z24 5 spd    $1250 obo As is or $1400 Cert
225, 477 kms on the Body of the Car
116,000 kms on the Motor and Trans
The motor was changed in 2002 by GM and there is a pic of this sticker on the Motor
Car was certified March 26, 2009 with 223, 950 km on the car so ive put under 2000 km on the car since ive had it
HO cams, Ported and Polished LD9 head with 3 angle Valve job, 1mm stainless valves and HO Valvetrain, Stock intake manifold and injectors, Pacesetter Ceramic Coated Header, Stock motor mounts, Stock Headlights and corners, Stock shifter assembly, Stock suspensionwith 4000 KM on it all, 15 inch steel rims freshly painted and Nokian winter rubber, Prothane Trans mounts, AC Delco Battery, Stock Cat to be welded back on and cutout can stay or go, whatever changes you want made with HPT upon Delivery, Unorthodox Racing Underdrive Pulley can stay or go will supply stock pulley if wanted.  Brand new top end gasket set, brand new water pump, brand new clevite timing assembly all done with Motor work.  Clutch is good and firm.  AC deleted with Delco delete pulley due to system not working and needing to much to fix.
Can add any of the following parts especially if not already removed for a better deal then what is listed below
All parts are plus ship or can be picked up, i can deliver a bunch of parts to different people all at once in the GTA area from Sudbury
I will either strip the car right down to nothing and scrap it or restore it to mostly stock without going back into the engine and sell it that way
If anyone thinks of any parts i didnt list here that they would want let me know
Parts List, Prices are OBO and priced to move fast
310 CC GM SC Injectors $25
All suspension bars for $125 or
Eibach Rear Sway bar and GM Tie Bar  $75
K Frame Brace $25  never installed
RSM Racing Front and Rear Strut Bars $75  pic of the front one
Level Zero MotorSports Upper LD9 Motor Mount with Solid Bushing included and Lower dogbone with Bushings  $150   Mint Condition   Pic of upper
Getrag F23 Trans with around 125k on it purchased from Greg Roy  $300
Extrude Honed HO Manifold and 56 mm TB this manifold was moddifed by GM, oil inside the Pic was from cleaning when i got it    $200
Innovate LC1 with DB Blue Gauge, barely used  $200
M&H Racemaster Slicks and Primax 333 14x6 Rims, 5 passes on these $500
Motegi MR7 Rims and Nexen 3000 Tires, 7500 KM on Tires, Rims have some scuffs and marks from Previous Owner  $400
B&M Short Throw, complete assembly ready to drop in   $150
Induction Dynamics Cold Air Intake with Huge K&N Filter $100
Custom made High Output Twin cam IDI Cover $100
Black Corners and Headlights lens are mint on both   $100
Eagle H Beam Rods   Brand New never used  $200
2.3 Oil swap parts including Modded Oil Pan by Certified TIG Welder  $200
Edited 4 time(s). Last edited Monday, September 21, 2009 9:50 PM
