All Items were in the Sunfire which i barely used this year.
ENERGY 12" SUBWOOFER
Model No: ENC12
SRP: $249.99
Patented Ribbed Elliptical Surround
 Kevlar Reinforced Turbine Tip TM Dust Cap
 Woven Glass Fibre Cones
 CNC Machined Aluminum Baskets
 Woofer Girlls Included
I have 2 asking $120 each
ENERGY 6.5" CONVERTIBLE CAR  SPEAKER
Model No: ENC650CV
UPC Code: 059497112314
SRP: $299.00
2 sets asking $140 each
Amplifiers
 Amplifier KS-AR7001
Continuous Power Output (RMS) at 4 ohms, 20Hz to 300Hz, less than or equal to 1% THD+N (CEA-2006 compliant) 250W
Operation Channel 1
Maximum Power Output 600W
RMS Power Output 400W x 1 into 2 ohms, 250W x 1 into 4 ohms
Class Class-AB
MOS-FET Output Stage Yes
MOS-FET Power Supply Yes
LPF 50 - 300Hz, -18dB/oct
Subsonic Filter 20 - 50Hz, -18dB/oct
Phase Control (0/180 degree) Yes
Variable Input RCA Level Control 0.3 - 6V
Variable Speaker Input Control 1.2 - 12V
Variable Bass Boost Control 45Hz, 0-18dB
Gold-Plated RCA Jacks Yes (In/Out)
Power Supply Block Terminals 4AWG, Gold
Speaker Out Block Terminals 8AWG, Gold
Protection Circuitry (Thermal / Short Circuit / Overload / DC Offset) Yes
Anti-Pop Circuit Yes
Control Panel on the Top (Cover) Yes
LED Illumination Yes
Frequency Response (+0, -3dB) 20 - 300dB
Signal-to-Noise Ratio (reference: 1W into 4 ohms), CEA-2006 Compliant More than 60dBA
Load Impedance 4 ohms
Allowance 1 to 8 ohms
Line Input Level/Impedance 1V/20k ohms (0.3 - 6V allowable)
Distortion (at 1kHz) Less than 0.1%
Dimensions (W x H x D) 400 x 60 x 288 mm
retail is $279 have 2 asking 150 each
Amplifiers
Amplifier KS-AR7004
Continuous Power Output (RMS) at 4 ohms, 20Hz to 20,000Hz, less than or equal to 1% THD+N (CEA-2006 compliant) 100W x 4 channels
Operation Channel 4, 3, or 2
Maximum Power Output 800W
RMS Power Output 200W x 2 into 4 ohms, 120W x 2 into 2 ohms, 100W x 4 into 4 ohms
Class Class-AB
HPF 30 - 500Hz, -18dB/oct
LPF 30 - 500Hz, -18dB/oct
Subsonic Filter 20Hz
Frequency Response (+0, -3dB) 5 - 50,000Hz
Signal-to-Noise Ratio (reference: 1W into 4 ohms), CEA-2006 Compliant More than 80dBA
Allowance 2 to 8 ohms
Allowance (Bridged) 4 to 8 ohms
Distortion (at 1kHz) Less than 0.04%
retail is $329  asking $150
9" Widescreen NTSC/PAL Monitor with TFT Active-Matrix LCD.
Wide Viewing Angle
336,960 Pixel Resolution
Roof Mount Design
 IR Transmitter For Wireless Headphones
Wireless Remote Control
Input Terminals: Video (2 pairs) - Audio (2 pairs)
Output Terminals: Video (1 pair) - Audio (1 pair)
MSRP $650 asking $250
6.5" Widescreen Headrest Monitor
TFT Active Matrix LCD with Wide Viewing Angle
280,800 Pixel Resolution
Mounting Shroud Included for Easy Installation
On Screen Menu
MSRP $449 asking $200
Will meet depending on area and will sell everything for $750 OBO if sold by the weekend there is over $3000 worth of retail product here that is barely used I still have the boxes and everything
will seperate need it gone pm me an offer
