ENERGY 12" SUBWOOFER
Model No: ENC12
SRP: $249.99
Patented Ribbed Elliptical Surround
 Kevlar Reinforced Turbine Tip TM Dust Cap
 Woven Glass Fibre Cones
 CNC Machined Aluminum Baskets
 Woofer Girlls Included
I have 2 asking $150 each
ENERGY 6.5" CONVERTIBLE CAR  SPEAKER
Model No: ENC650CV
UPC Code: 059497112314
SRP: $299.00
2 sets asking $160 each
Amplifiers
Amplifier KS-AR7001
Continuous Power Output (RMS) at 4 ohms, 20Hz to 300Hz, less than or equal to 1% THD+N (CEA-2006 compliant) 250W
Operation Channel 1
Maximum Power Output 600W
RMS Power Output 400W x 1 into 2 ohms, 250W x 1 into 4 ohms
Class Class-AB
MOS-FET Output Stage Yes
MOS-FET Power Supply Yes
LPF 50 - 300Hz, -18dB/oct
Subsonic Filter 20 - 50Hz, -18dB/oct
Phase Control (0/180 degree) Yes
Variable Input RCA Level Control 0.3 - 6V
Variable Speaker Input Control 1.2 - 12V
Variable Bass Boost Control 45Hz, 0-18dB
Gold-Plated RCA Jacks Yes (In/Out)
Power Supply Block Terminals 4AWG, Gold
Speaker Out Block Terminals 8AWG, Gold
Protection Circuitry (Thermal / Short Circuit / Overload / DC Offset) Yes
Anti-Pop Circuit Yes
Control Panel on the Top (Cover) Yes
LED Illumination Yes
Frequency Response (+0, -3dB) 20 - 300dB
Signal-to-Noise Ratio (reference: 1W into 4 ohms), CEA-2006 Compliant More than 60dBA
Load Impedance 4 ohms
Allowance 1 to 8 ohms
Line Input Level/Impedance 1V/20k ohms (0.3 - 6V allowable)
Distortion (at 1kHz) Less than 0.1%
Dimensions (W x H x D) 400 x 60 x 288 mm
retail is $279 asking 180
Amplifiers
Amplifier KS-AR7004
Continuous Power Output (RMS) at 4 ohms, 20Hz to 20,000Hz, less than or equal to 1% THD+N (CEA-2006 compliant) 100W x 4 channels
Operation Channel 4, 3, or 2
Maximum Power Output 800W
RMS Power Output 200W x 2 into 4 ohms, 120W x 2 into 2 ohms, 100W x 4 into 4 ohms
Class Class-AB
HPF 30 - 500Hz, -18dB/oct
LPF 30 - 500Hz, -18dB/oct
Subsonic Filter 20Hz
Frequency Response (+0, -3dB) 5 - 50,000Hz
Signal-to-Noise Ratio (reference: 1W into 4 ohms), CEA-2006 Compliant More than 80dBA
Allowance 2 to 8 ohms
Allowance (Bridged) 4 to 8 ohms
Distortion (at 1kHz) Less than 0.04%
retail is $329  asking $250
In-Dash 7" Widescreen Monitor
KV-M706
FEATURES:
Motorized 7" Widescreen Monitor
TFT Active Matrix LCD with Wide Viewing Angle
 Angle Select
1 AV Inputs / 1 AV Output
1 AV-BUS (For TV Tuner)
retail is $599 asking $280
Will Ship and will sell everything for $1100 if sold by the weekend
Door panels, Dash, under dash, rear panels, and center console with built in TV
asking $500 plus oem cavalier or sunfire interior no seats.... remember there is also a $450 tv included in that price
will include this dash for extra
95-02 Chevy Cavalier/Pontiac Sunfire Triple Pillar Pod
1 air fuel 2 volt gauges
retail is $461.96
Asking $200
7 Color Wireless Led Underbody Kit
Features: Includes:
Ultra Bright LEDs
     378 Super Bright LEDs for 360 degree lighting 2 48" 7 Color Tubes - Wide Angle LEDs
2 36" 7 Color Tubes - Wide Angle LEDs
Water-Resistant High-Impact Optical acrylic tubes
Easy to use 7 Color Control Box
Wireless Remote Control
12 Flash Patterns & 5 Music Patterns
Detailed Programming Instructions
Mounting Hardware
1 Year Limited Warranty
Programming Functions:
     Strobing Effects
     Chasing Colors
     Fade Colors
     7 Unique Colors
Operation - 12 Pre Programmed Patterns
     Pattern memory recall
Music Activation - sound activating patterns
Solid illumination or flash patterns
Blue, Green, Red, Yellow, Purple, Aqua and White
Retail Price $199.99
also comes with
6pc. Expandable 7 Color Led Interior Kit
Includes:
4 15" Wide Angle LED Tubes
30 LEDs Per Tube
Control Box w/ Music Controller
NEW Pause Button
One Year Warranty
Mounting Brackets included
Features:
36 Second Color Scan
18 Second Color Scan
5 Second Color Scan
36 Second Color Fade
18 Second Color Fade
5 Second Color Fade
Music Mode with Sensitivity Controller
Colors Include:
Blue
Red
Green
Purple
Pink
Aqua
White
Yellow
Pause button built into controller, simply press to hold on any color you desire.
NEW Expandable Kit, Allows you to have a total of 6 Tubes! Pick additional 15" Tubes or 9" Tubes to customize your car even more.
These super bright LED lights can fit under any car seats or dash to add a perfect amount of accent lighting. Each tube has 30 LEDs.  120 LED Lights total for a perfect amount of lighting for any car.  Features no LED Spotting so it gives off a true glow
Retail Price $109.99
asking $160[size=default]
[size=default]
if all together will sell for $2000
