what what rms is it  at 2 ohm ??
AMP or SUB
The amp is kinda spoken for @ $300 but I would like to have a buyer for everything
Now Accepting 2005 Team Applications
Team Sonic Illusion
Here are the full details
500d amp
16-ST500D
RMS Power 4ohm 250 x 1
RMS Power 2ohm 500 x 1
RMS Power 1ohm N/A
THD 4ohm 0.50%
THD 2ohm 0.75%
THD 1ohm N/A
S/N Ratio >95dB
Variable Low-Pass Filter 50-250Hz
Variable Subsonic Filter 20-50Hz
Filter Slopes 18dB
Input Sensitivity 250mV-5V
Input Impedance 22Kohms
Frequency Response +/- 1dB 10Hz-650Hz
Fuse Rating 25A x 2
Dimensions 6.5" x 2 " x 10.4"
15" SHP sub
15-SHP15
Nominal Impedance Znom ohms 2 (x 2)
DC Resistance DCR ohms 1.68 (x 2)
Resonant Frequency Fs Hz 29.7
Mechanical Q Qms 4.8
Electrical Q Qes 0.352
Total Q Qts 0.33
Xmax (linear) in 0.467
Xmax (mechanical) in 1
Sensitivity 2.83 volts dB 93
Voice Coil Diameter d in 3
Voice Coil Length hvc in 1.4
Voice Coil Layers n 4
Voice Coil Type Dual
Continuous Power watts 500
Maximum Power watts 800
Magnet OD in 7.5
Magnet Thickness in 2
Magnet Weight oz 192
Frame OD in 15
Mounting Hole in 14
Mounting Depth in 8.25
Speaker Weight lbs 39
Surround Thickness mm 1.7
Driver Displacement cf 0.29
Sealed c.f. 2.00
Vented SPL c.f. 2.50
Round vent for 55Hz in. 6" x 6"
Slot vent for 55Hz in. 6" x 6" x 8.75"
Alternate slot vent for 55Hz in. 4" x 10" 13.5"
Vented Low Tuning c.f. 2.6
Round vent for 38Hz in 4" x 8.75"
Slot vent for 38Hz in. 3" x 6" x 12"
Alternate slot vent for 38Hz 4" x 8" x 30"
All prices listed are Canadian
Model #15-SHP15
MSRP $1400
Was asking $850 w/box
Model #16-ST500D
MSRP $850
Was asking $450
The time has come that this really needs to go.
Asking $800 (Sub, Amp, Box)
Team Sonic Illusion
orange sub and i think the smaller bottom amp
Thanks for the Pic J
Team Sonic Illusion
